Labroides
Flight distance : 9991457 ft
I'd be more concerned about:
• Airline pilots that have been scared by a flurry of unsubstantiated reports of drones in close proximity to aircraft
• Investigators with little knowledge of drones and their limitations and showing no skepticism when looking into very dubious reports..
• Ignorant journalists that want to push a sexy story
If you look at official incident reports for the "incidents" mentioned in that article you see some very dubious reports.
1. (at FL70 = 7000ft)
https://www.airproxboard.org.uk/ ... eport%202016229.pdf
THE A320 PILOT reports that during the intermediate approach from LAM, a large drone was seen by the flight crew, moving in a relative position from the forward left to the rear left of the aircraft. He assessed the drone to have passed less than 100ft from the aircraft (~20m) and possibly within the wingspan. The drone itself was blue and disc-like in structure, with a single rotor, approximately 50cm in diameter.
2. (at 3500 ft)
https://www.airproxboard.org.uk/ ... eport%202016242.pdf
The A320 pilot reports departing from Heathrow RW27 when, in the climb out, at approximately 3500ft, a drone passed overhead the aircraft. It was close enough to identify that it was red in colour and the design seemed to consist of two modules.
It was difficult to judge the distance without knowing the size of the drone, but it didn’t look too far off the right wing, and so he estimated it was 50m away.
3....(at FL100 = 10000 ft)
https://www.airproxboard.org.uk/ ... eport%202016239.pdf
both crew noticed an object in the 1 o’clock position which had no lighting and appeared stationary. They tracked it for about 5sec as it passed down the right side. They both questioned 'Was that a drone? At 10,000ft!'.
The pilot stated that it was clearly identifiable as a large drone and not a bird or balloon. It was dark in colour with a T-shape landing frame, with multiple arms and rotors (6-8) and passed just below the right wing
Back in the 1970s when pilots commonly reported they saw UFOs but very few people believed there really were flying saucers buzzing around.
But in the 21st century the UFOs are called drones and almost everyone gullibly believes they must be.
One reason that all these reports end with .. The drone operator could not be traced, is because there was no drone or operator.
