John Smith
So I take it your go app is connected to your controller but you have no video background?
"I can take regular video and pictures" means your controller is sending telemetry to your ac
If your go app is showing drone info like battery levels and heading, then it would mean your ac is sending telemetry to your controller.
Your controller uses 5.8ghz for telemetry so that appears to be fine.
Your camera is powered and functional (writes video to SD) which implies your cables are connected properly.
The only thing malfunctioning is your fpv which is an indictment of your 2.4 ghz modules.
Since your antenna modules are new, it's unlikely they're bad, so I would doublecheck the tiny little connectors where they plug into the gimbal to make sure they're connected properly.
Otherwise, I would suspect the problem will lie in the yaw motor circuit board which has the fpv transmitter circuitry and into which the above mentioned antennae connect. You'd have to disassemble the yaw motor circuit housing and examine it to see if there's any visible damage.
