So my gimbal just tilts up and down when I start it up everytime, manually tilting the camera through the dial does nothing. Did an IMU calibration, gimbal calibration (it doesnt do anything), the gimbal status is listed as normal on the dji go app with no errors or warnings either. Here's a video showing my issue:
I figured out a temporary fix, this issue is caused from the camera not moving all the way up or down upon calibration so when it goes down I just push it down a little further it goes fine. Now what would be preventing it from reaching that one last degree it needs to move down is beyond me....The gimbal should feel slightly spring loaded when the phantom is off and you tilt the camera 90 degrees down correct?
