DanTup
Flight distance : 13245 ft
thehippoz Posted at 2017-4-2 10:26
Found flying it the only way to get the gimbal adjust right. Look at what way it's tilted in the air, then on ground adjust the roll one. Restart and take it back up, do it again. A good imu calibration helps (level surface, cold, done before the internal fan on the ac kicks on). Kind of a dumb question, you in sports mode?
I'm not in Sports mode (though the controller did come with it switched into sports mode out of the box!).
To make it level, I have to set the roll to 2.0 (which seems quite high), but then it doesn't seem to completely solve the issue while flying; it often falls out of line again.
I've tried IMU, Compass and Gimbal calibration many times though none seem to have helped (I haven't tried IMU calibration cold or without fans kicking in though). |
