DJI-Jamie
Flight distance : 112405 ft
Rene vd Meer Posted at 2017-4-3 05:08
I bought the drone in December last year. I did notice height variations then, but I thought it was caused by the gimbal protection (which I removed).
A month ago I had to fly close to the ground. Then I noticed this behavior the first time.
I have seen that the VPS height can be very low, shouldn't VPS prevent the drone from touching the ground?
The VPS readings can be affected depending on the lighting conditions, color and the solidity of the surface it's flying over. On pages 22-23 of the P4 manual, it goes over the conditions that can effect the performance of the sensors:
https://dl.djicdn.com/downloads/ ... ser+Manual+v1.4.pdf
If the VPS isn't in the optimal conditions, the performance will be off. Given the last screenshot you provided, it should have been a little more accurate barring if the ground is becoming elevated or if you were above a very soft patch of ground where the sonar like component is easily absorbed (like sand) that we can't see. If this continues to be an issue, you may want to look into having the unit sent in for further evaluation and potential repair. |
