Coloring your props with RIT
Phantomski
Flight distance : 14869882 ft
As you can see I used RIT (from WalMart) and hot water, after masking some areas off with electrical tape. Yes, some color got under the tape.. perhaps i could use painter's tape? Not sure.. Also, the Red + yellow later, turned brown, I should have skipped yellow, or masked some red with more tape. Anyways, now I got relatively ok color props. I did a set of red and set of green, this way I can put red on the front and green on the rear. BTW, colors do not really help much with orientation. At a distance it is irrelevant, but it still looks cool, and nicer than white I guess.
The props that show color not catching - I got them oin amazon, and do not believe they were DJI. Very flexible, and made of some different plastic - the color did not catch. They flew back to amazon.
2017-4-1
