Nigel_
Flight distance : 388642 ft
Heathrow is at 83 ft altitude, so only 9,927 ft to go!
A Phantom 4 Pro in sports mode would take 22 minutes to get up and back down at full throttle according to the specs, if it was possible to remove the 500m height limit. Realistically it would be unlikely to achieve the specs 100% of the time, especially with the winds likely at 10000ft above ground, so I doubt it would make it on a single battery without turning the motors off for a while on the way back down, but if you did turn the motors off it would probably get blown a long way away and still not make it back!
A 6/8 rotor multicopter as seen in this report is going to be less efficient than the P4P so unless it was built specifically for setting an altitude record it is highly unlikely to succeed. If it was built specifically for achieving high altitudes then it wouldn't be a 6/8 rotor machine, and in any case you wouldn't attempt to set your record in the middle of the holding area for passenger aircraft queuing to enter one of the worlds busiest airports!
These are UFOs which nobody seems to be able to photo, video, track, locate or provide any reasonable explanation for why anyone would attempt to put them there with a frequency sufficient for aircraft to be seeing them regularly.
