Nexus 7 2013 USB connect problems
752 3 2017-4-5
xedder
Flight distance : 4725154 ft
i have a nexus 7 2013 that is having usb connection problems.I have turned on bebugging and set it to PTP setting but it keeps going back to charging mode.I did a factory
reset twice thinking that would help.Yesterday it worked fine flew with litchi no freezing or lost connection i was very happy, today cant even connect.I know when its
going to connect as a little joystick icon appears, today nothing just back to charging.I have 3 usb cables ive tried switching out as well but will get new set to try.
I thought the nexus 7 for mavic was ok ,it was working fine on my P3. Any ideas or work arounds you guys know of??  thanks
2017-4-5
Thudd
Flight distance : 1557283 ft
I use a Nexus 7 2013 as well.  It works well for the most part, very few crashes.  When I first connect to controller or drone, I have to pull the usb cable from the controller, and reconnect it for the app to activate.
2017-4-5
xedder
Thudd Posted at 2017-4-5 06:54
Do you have to go through all the debugging crap to get your nexus working? It seems not to like when i go to set PTP on dev options.When it works it works good but it just a pain to be fighting to get flying.Love my mavic and nexus just wish they could along better.
2017-4-5
Thudd
No I do not have to debug. I do have very few other apps installed. I also run an app called advanced task killer to keep possible problematic apps from conflicting with DJI Go 4. There are times when DJI Go 4 will startup when I power on the Magic. When it does not, I just unplug the USB cable and plug it back in. That useally does the trick. Sorry for the non tech answer but I hope it helps. Good luck.
2017-4-6
