How to install latest firmware (FW)
32727 165 2015-3-1
pidetectives
Flight distance : 2131073 ft
Well be flying shortly and will give a quick update when done.
2015-3-1
dundee
Flight distance : 33550 ft
Thailand
I think this info fits in this thread
Thanks to Captain Obvious. (Very good job)
http://forum.dji.com/forum.php?m ... amp;page=1#pid62864
2015-3-1
RichJ53
Flight distance : 1837356 ft
dundee Posted at 2015-3-2 01:26
Believe me, i put some time in this problem.
Let us first see how many members will post here "The ...
As you know, I will finally have my hands on my new Inspire 1 next week. Hopefully I will not need to install the latest firmware update. But if I do, I will use your advice THANK YOU.
DJI should give you a direct line on their support channel   then maybe we could be some real help with issues when they come up.
2015-3-1
rfrye
Flight distance : 309606 ft
Dundee,
Did exactly what you kindly recommended in all the posts (and thank you).
Aircraft still would not take it.
I'm starting to wonder id DJI Help Line guy is right that it automatically updates on Android
2015-3-1
dundee
Thailand
RichJ53 Posted at 2015-3-2 02:37
As you know, I will finally have my hands on my new Inspire 1 next week. Hopefully I will not need ...
Thanks for your thrust.
2015-3-1
JRoussell
Thanks dundee!
2015-3-1
dundee
Thailand
rfrye Posted at 2015-3-2 02:41
Dundee,
No, nothing to do with the APP
The APP will show progress, but apparently it's buggy too.
You don't need Android or IOS or whatever device connected to your transmitter (TX)
Update start as soon as you power up the craft.
2015-3-1
rfrye
dundee Posted at 2015-3-2 01:46
Yes weird, thats why i wrote on the flowchart :
No D---DDD sound after 45 minutes ?
  Just contin ...
Followed the Dundee procedures exactly.
My bird still won't take an up date - I ran it for 50 minutes before powering down and checking the SD card in my computer. No results files at all.
Bird continues to say "firmware is latest- normal".
Could DJI Help Line guy be right in saying "if you run androids that updates are automatic"?
2015-3-1
david.spencer
Flight distance : 7192 ft
Just done this, thanks for making it so simple. Whats the big positives you have all noticed in this firmware
Cheers, Dave
2015-3-1
panox
Flight distance : 568819 ft
dundee Posted at 2015-3-1 19:58
Maybe these 2 flowcharts can help some members.
Nice, but I never got a GS-file.  My files always are named:  WM610_FW_RESULT_AB.txt  (AB=Abort?)
I checked the beeping sound. There was no D-DD, and the D-D-D-D has stopped.
It would be very nice if someone from DJI could reactivate my bird which is dead just by trying to update.
Many other electronic equipments or software have a  "rool-back" to the version before.
Not so Inspire 1.
A failed update means aircraft is grounded.  "We have no tools for resetting to factory default settings" said the support.
Now I'm stuck after two days of frustration.
2015-3-1
pidetectives
For some reason I don't feel confident with the update,
2015-3-1
dundee
Thailand
panox Posted at 2015-3-2 04:17
Was is possible to update the transmitter (TX) ?
2015-3-1
panox
Yes, both of them. But I get no connection. How long should I wait before I shut down the Inspire-update? 1 hour , 2 hours?
2015-3-1
Gatorone30
Flight distance : 1145489 ft
Thank you Dundee!!!!
2015-3-1
dundee
Thailand
panox Posted at 2015-3-2 05:41
Yes, both of them. But I get no connection. How long should I wait before I shut down the Inspire-up ...
45 minutes is enough if you feel nothing is going on
Power on TX and Craft.
Led on TX red indicates no signal (TX not see the Craft)
If so, try rebinding your Transmitter to the Craft
2015-3-1
Gatorone30
dundee Posted at 2015-3-2 06:42
Led on TX red indicate ...
Mine never beeped either, but waited 45min and did the check and success ! By following your chart the updates went  smooth. Will do a check flight tomorrow.
2015-3-1
dundee
Thailand
Gatorone30 Posted at 2015-3-2 07:17
Mine never beeped either, but waited 45min and did the check and success ! By following your chart ...
Nice to see the flowcharts helped you
2015-3-1
dundee
Thailand
TIP: Play with simulator for a while if you not sure. (if you have IOS)
2015-3-1
pidetectives
Just came in from flying the bird and it did very well. The only thing was some vibration in the arms.
Never had that issue before.But made new cop friends.
2015-3-1
subwar
Sweden
Does it matter if you update the Rc first or the Inspire first?
Is the feature working inside the app that is supposed to tell you your firmware is not up to date, mine says it is but how could it be?! (iOS)
2015-3-1
lakecreekranch
Flight distance : 61860 ft
Amazing...  Thank you very much for taking the time to put all that together and post it...  I for one very much appreciate it...
2015-3-1
Colonel Angus
Flowed your flow chart worked like a Champ!! TY
2015-3-1
CrabHawk
Flight distance : 7782 ft
Classic! It took 6 minutes for the bird then 5 minutes for the TX I had it STARTED up in 14 minutes from start to finish.
I'm sorry to hear so many people are having such problems DARN IT.
2015-3-1
dundee
Thailand
pidetectives@ya Posted at 2015-3-2 07:57
Just came in from flying the bird and it did very well. The only thing was some vibration in the arm ...
2015-3-1
dundee
Thailand
CrabHawk Posted at 2015-3-2 10:50
Classic! It took 6 minutes for the bird then 5 minutes for the TX I had it STARTED up in 14 minute ...
Well, 6 an 5 minutes indicates your bird was already updated
2015-3-1
dundee
Thailand
Colonel Angus Posted at 2015-3-2 09:29
fly safe Angus
2015-3-1
dundee
Thailand
subwar Posted at 2015-3-2 08:00
Is the feature working inside the  ...
No, it does not matter, as long as you not forget to upgrade them both.
My 2 cents
Do not power up tranmitter during upgrade of the craft. This is a kind of security that it
can't interfere during upgrading the craft.
And visa versa for the transmitter.
2015-3-1
dundee
Thailand
lakecreekranch@ Posted at 2015-3-2 08:46
Amazing...  Thank you very much for taking the time to put all that together and post it...  I for ...
It' amazing how we, all members can figure many things out, with or without decent documentation.
2015-3-1
ZeroCool
this is very cool Dundee! thanks.
2015-3-1
Dangair
Dundee, do you work for DJI? If not you should. They should pay you for this. Better yet they should give you a new Inspire for doing their work for them. Great job man. Hats off to you. DJI ..... If your reading this ..... The customers are doing your work for you! That's not how it's supposed to work.
2015-3-1
Prop-Lock Girl
Flight distance : 2419163 ft
Why is DJI not able to make such an easy to understand flowchart?
Thank you for creating and sharing!
2015-3-1
dundee
Thailand
Dangair Posted at 2015-3-2 15:22
Dundee, do you work for DJI? If not you should. They should pay you for this. Better yet they should ...
Together we are strong
2015-3-2
kappaOS
Flight distance : 1276778 ft
pidetectives@ya Posted at 2015-3-2 01:42
Weird never got any DDD or DA DA DA of any kind. only on the remote
mine is very low volume.
2015-3-2
kappaOS
Just updated mine with dundee´s advice.
========== 2014.01.01 00:00:02 unsynchronized ======
Packet: WM610_FW_V01.02.00.17.bin
Upgrading ...
Result: Success.
Actually it took only about 3 minutes to upgrade the Craft. (Beep changed from D-D-D to D----D-D)
The Remote took about 8-10 minutes (wait for green-light on the remote)
cheers.
2015-3-2
kappaOS
JUST NOTICED:
BATTERY FIRMWARE:
TB47 : 03.03 Loader 02.06
TB48 : 03.00 Loader 02.06
can anyone confirm ?
PS. I updated to .0.17 with the TB48 inserted.
2015-3-2
dundee
Thailand
kappaOS Posted at 2015-3-2 18:28
JUST NOTICED:
BATTERY FIRMWARE:
On IOS v1.0.2
I tested this. TB47 or TB48 not changes for me. Always Firmware 03.00 Loader 02.06
2015-3-2
DJI-Autumn
Just see that!
Well done man!!!
2015-3-2
dundee
Thailand
DJI-Autumn Posted at 2015-3-2 19:24
Just see that!
Well done man!!!
2015-3-2
tc_chay
Brunei
dundee
great flow chart and update mine without any problem!!!!
2015-3-2
Dave E
Flight distance : 729560 ft
Great post Dundee.
2015-3-2
