Phantom 3 Professional No Image Signal HELPPPP!!!
1614 10 2017-4-11
KevinTurboX
Flight distance : 121995 ft
Hello, I have a very important shoot tomorrow. I have updated my P3P to the latest firmware 1.10, also the RC and my iPhone are up to date. Now I get NO IMAGE SIGNAL. I've been messing with firmwares and past firmwares for a whole day to no avail. Any chance someone has a solution??? or do i have to send it to DJI? HELP!
2017-4-11
DJI-Jamie
Flight distance : 112405 ft
Is the RC firmware up to date as well? Also, try the following button combinations to ensure that the RC and aircraft have a solid connection:
Reset the RC:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter on the controller then turn the controller off.
* Turn on both the aircraft and the controller and relink the remote.
Manually relink the RC to the aircraft:
* Turn on both the aircraft and the controller.
* Press C1, C2, and the record button on the controller, then the controller will beep like D-DD. This may take a few seconds of holding it.
*While holding the buttons, press the wheel on the right side of the controller and then the first light of the controller will become blue and it will constantly beep DDDD.
* Use a pen to click the linking button on the aircraft and hold for 3-5 seconds, and then take the pen off the aircraft and wait, it will be linked soon.
You would want to make sure that the SD card is clear of the previous .bin file or .txt files. If this persists, could you please tell me what color the camera LED indicator is?
2017-4-11
KevinTurboX
DJI-Jamie Posted at 2017-4-11 15:49
Reset the RC:
The light is green. I can record and take take photos and control the camera. but no image signal feed.
2017-4-11
Phantomski
Flight distance : 14869882 ft
did you search in the forums? There's a lot of discussions about no signal. Please tell us what the "about" in the GO app menu shows, it's the ... at the bottom of the menu. Let's see what that shows..
Below u see a few images, how to get there, this is from my advanced and pro, they r the same.
2017-4-11
DJI-Jamie
KevinTurboX Posted at 2017-4-11 18:05
Did you try any  of the button combinations I provided? Could you verify what firmware versions are on both components?
2017-4-11
KevinTurboX
Hey Jamie, yes I have tried the combination and it pairs fine. Just still no signal. I got a hold of another P3P and paired it with the same RC and it works perfectly. So something must be wrong with the Drone or Gimbal firmware.
2017-4-11
KevinTurboX
Versions are all up to date. 1.10.09 for aircraft, 3.1.8 for iOS app, 1.8 for RC.
2017-4-11
keith.pearceran
I have the same problem but intermittent. As long as the aircraft and transmitter are close the camera works fine and when you first take off everything seems to be working fine. It will record anywhere from 15 to 25 seconds and then the camera switches back to still shots. It will snap stills with no problem. It will record with no problem as long as the P3P isn't flying, once in the air it starts giving a weak image transmission signal. the image quality is fine as long as you are not recording video. All firmware is up to date according to the app but yet I still get a controller firmware update required message from time to time, when I attempt to update it immediately aborts and gives a check network connection. All connections are on and I'm connected to Hughesnet 5g service. I have not had this issue until recently and the P3P has no damage history (no crashes). It seems to be a signal transmission problem.  Any advise would be appreciated.
2017-4-12
DJI-Jamie
KevinTurboX Posted at 2017-4-11 23:05
If you had already tried downgrading and the issue persists, then there's most likely an issue with the video module that's in the camera/gimbal component itself that would require sending the unit in for service. The NA Support team would be able to help with shipping as well.
2017-4-12
DJI-Jamie
keith.pearceran Posted at 2017-4-12 06:32
I had responded to you on your own thread.
2017-4-12
KevinTurboX
DJI-Jamie Posted at 2017-4-12 14:12
any idea?
[00013029]========== remo-con disconnect. boot(15) ============
[00013201]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x50ce09ab].
[00013236]Packet upgrade start...
[00013282]Packet checking...
[00013320]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013386]Done.
[00013426]Version checking[1]...
[00025959][03 05][00] device not detected.
[00038496][03 06][00] device not detected.
[00038543][04 00][00] v1.40.0.0 -> v1.40.0.0
[00051080][09 00][00] device not detected.
[00063633][11 00][00] device not detected.
[00076172][12 00][00] device not detected.
[00088710][12 01][00] device not detected.
[00101246][12 02][00] device not detected.
[00113779][12 03][00] device not detected.
[00120622][15 00][00] device not detected.
[00133157][17 00][00] device not detected.
[00145692][17 01][00] device not detected.
[00158229][19 00][00] device not detected.
[00158265][01 00][00] v1.23.3419 -> v1.23.3419
[00158301][01 01][00] v1.23.3419 -> v1.23.3419
[00161069][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00161105]Done.
[00163140]Waiting for user confirm...
[00173174]Timeout, start upgrade automatically.
[00173251]Firmware upgrading[1]...
[00174018][08 00] Firmware upgrade start...
[00705589][08 00] Firmware upgrade finished successfully.
[00705631]Done.
[00705664]Version checking[2]...
[00718197][03 05][00] device not detected.
[00730735][03 06][00] device not detected.
[00730776][04 00][00] v1.40.0.0 -> v1.40.0.0
[00743314][09 00][00] device not detected.
[00755851][11 00][00] device not detected.
[00768389][12 00][00] device not detected.
[00780925][12 01][00] device not detected.
[00793458][12 02][00] device not detected.
[00805991][12 03][00] device not detected.
[00808806][15 00][00] device not detected.
[00821342][17 00][00] device not detected.
[00833877][17 01][00] device not detected.
[00846416][19 00][00] device not detected.
[00846451][01 00][00] v1.23.3419 -> v1.23.3419
[00846486][01 01][00] v1.23.3419 -> v1.23.3419
[00846649][08 00][05] v0.12.0.4 -> v0.12.0.4
[00846685]Packet upgrade failed at version checking.
[00015204]========== remo-con disconnect. boot(15) ============
[00015242]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x28527b69].
[00015279]Packet upgrade start...
[00015322]Packet checking...
[00015362]Packet vlink 01.10.0090 <-> 01.10.0090.
[00015429]Done.
[00015466]Version checking[1]...
[00015544][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015624][03 06][00] v2.2.6.19 -> v2.4.20.28 need upgrade.
[00015775][04 00][00] v1.40.0.0 -> v1.48.0.0 need upgrade.
[00016004][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016124][11 01][00] v1.8.0.0 -> v2.0.0.33 need upgrade.
[00016214][12 00][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00016314][12 01][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00016440][12 02][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00016540][12 03][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00029077][15 00][00] device not detected.
[00029170][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029302][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029361][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029399][01 00][00] v1.23.3419 -> v1.32.5432 need upgrade
[00029436][01 01][00] v1.23.3419 -> v1.32.5432 need upgrade
[00041974][08 00][00] device not detected.
[00042041][09 00][00] v1.7.0.3 -> v3.0.0.10 need upgrade.
[00042078]Done.
[00044117]Waiting for user confirm...
[00054154]Timeout, start upgrade automatically.
[00054230]Firmware upgrading[1]...
[00069195][01 00] Firmware upgrade start...
[00014238][01 00] Firmware upgrade finished successfully.
[00014280]Done.
[00014315]Packet [C:\P3X_FW_V01.10.0090.bin] resumed, card sn [0x28527b69].
[00014359]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014429]Version checking[2]...
[00014494][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014574][03 06][00] v2.2.6.19 -> v2.4.20.28 need upgrade.
[00014617][04 00][00] v1.40.0.0 -> v1.48.0.0 need upgrade.
[00014738][11 00][00] v1.8.0.0 -> v1.8.0.0
[00014853][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015008][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015109][12 00][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00015188][12 01][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00015309][12 02][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00015408][12 03][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00027968][15 00][00] device not detected.
[00028066][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028196][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028289][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028337][01 00][05] v1.32.5432 -> v1.32.5432
[00028376][01 01][00] v1.23.3419 -> v1.32.5432 need upgrade
[00040915][08 00][00] device not detected.
[00040971][09 00][00] v1.7.0.3 -> v3.0.0.10 need upgrade.
[00041010]Done.
[00041057]Firmware upgrading[2]...
[00041225][01 01] Firmware upgrade start...
[00071564][01 01] Firmware upgrade finished successfully.
[00071624][12 00] Firmware upgrade start...
[00138777][12 00] Firmware upgrade finished successfully.
[00138837][12 01] Firmware upgrade start...
[00208874][12 01] Firmware upgrade finished successfully.
[00208932][12 02] Firmware upgrade start...
[00276423][12 02] Firmware upgrade finished successfully.
[00276488][12 03] Firmware upgrade start...
[00346541][12 03] Firmware upgrade finished successfully.
[00346861][03 06] Firmware upgrade start...
[00726017][03 06] Firmware upgrade finished successfully.
[00726088][09 00] Firmware upgrade start...
[00778225][09 00] Firmware upgrade finished successfully.
[00778310][04 00] Firmware upgrade start...
[00837221][04 00] Firmware upgrade finished successfully.
[00837261]Done.
[00837301]Version checking[3]...
[00837369][03 05][00] v34.2.0.9 -> v34.2.0.9
[00837449][03 06][05] v2.4.20.28 -> v2.4.20.28
[00837494][04 00][05] v1.48.0.0 -> v1.48.0.0
[00837613][11 00][00] v1.8.0.0 -> v1.8.0.0
[00837728][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00837768][11 01][00] v1.8.0.0 -> v2.0.0.33
[00837863][12 00][05] v1.11.0.0 -> v1.11.0.0
[00838059][12 01][05] v1.11.0.0 -> v1.11.0.0
[00838148][12 02][05] v1.11.0.0 -> v1.11.0.0
[00838223][12 03][05] v1.11.0.0 -> v1.11.0.0
[00850767][15 00][00] device not detected.
[00850834][17 00][00] v1.1.1.7 -> v1.1.1.7
[00850959][17 01][00] v1.0.2.7 -> v1.0.2.7
[00851019][19 00][00] v1.0.8.96 -> v1.0.8.96
[00851068][01 00][05] v1.32.5432 -> v1.32.5432
[00851107][01 01][05] v1.32.5432 -> v1.32.5432
[00863655][08 00][00] device not detected.
[00863719][09 00][05] v3.0.0.10 -> v3.0.0.10
[00863769]Packet upgrade failed at version checking.
[00015171]========== remo-con disconnect. boot(15) ============
[00015217]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x28527b69].
[00015255]Packet upgrade start...
[00015299]Packet checking...
[00015343]Packet vlink 01.10.0090 <-> 01.10.0090.
[00015419]Done.
[00015462]Version checking[1]...
[00015538][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015617][03 06][00] v2.4.20.28 -> v2.4.20.28
[00015664][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015777][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015898][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015941][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016028][12 00][00] v1.11.0.0 -> v1.11.0.0
[00016107][12 01][00] v1.11.0.0 -> v1.11.0.0
[00016198][12 02][00] v1.11.0.0 -> v1.11.0.0
[00016286][12 03][00] v1.11.0.0 -> v1.11.0.0
[00028835][15 00][00] device not detected.
[00028922][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029042][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029103][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029146][01 00][00] v1.32.5432 -> v1.32.5432
[00029186][01 01][00] v1.32.5432 -> v1.32.5432
[00041733][08 00][00] device not detected.
[00041804][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041851]Packet upgrade failed at version checking.
[00012486]========== remo-con disconnect. boot(15) ============
[00012522]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0xac165731].
[00012559]Packet upgrade start...
[00012599]Packet checking...
[00012754]Packet vlink 01.09.0060 <-> 01.08.0080.
[00012824]Done.
[00012862]Version checking[1]...
[00012930][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013006][03 06][00] v2.4.20.28 -> v2.4.20.18
[00013060][04 00][00] v1.48.0.0 -> v1.44.0.0
[00013166][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013271][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013310][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013399][12 00][00] v1.11.0.0 -> v1.10.0.0
[00013501][12 01][00] v1.11.0.0 -> v1.10.0.0
[00013586][12 02][00] v1.11.0.0 -> v1.10.0.0
[00013655][12 03][00] v1.11.0.0 -> v1.10.0.0
[00026194][15 00][00] device not detected.
[00026296][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026434][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026496][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026534][01 00][00] v1.32.5432 -> v1.30.5036
[00026572][01 01][00] v1.32.5432 -> v1.30.5036
[00039111][08 00][00] device not detected.
[00039177][09 00][00] v3.0.0.10 -> v3.0.0.10
[00039214]Packet upgrade failed at version checking.
[00012689]========== remo-con disconnect. boot(15) ============
[00012742]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xac165731].
[00012804]Packet upgrade start...
[00012874]Packet checking...
[00012931]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013016]Done.
[00013072]Version checking[1]...
[00013168][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013268][03 06][00] v2.4.20.28 -> v2.2.6.19
[00013339][04 00][00] v1.48.0.0 -> v1.40.0.0
[00013419][09 00][00] v3.0.0.10 -> v1.7.0.3
[00013528][11 00][00] v1.8.0.0 -> v1.7.0.0
[00013602][12 00][00] v1.11.0.0 -> v1.8.0.0
[00013701][12 01][00] v1.11.0.0 -> v1.8.0.0
[00013779][12 02][00] v1.11.0.0 -> v1.8.0.0
[00013857][12 03][00] v1.11.0.0 -> v1.8.0.0
[00026392][15 00][00] device not detected.
[00026492][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026612][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026678][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026717][01 00][00] v1.32.5432 -> v1.23.3419
[00026754][01 01][00] v1.32.5432 -> v1.23.3419
[00039397][08 00][00] device not detected.
[00039441]Packet upgrade failed at version checking.
[00012435]========== remo-con disconnect. boot(15) ============
[00012480]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0xac165731].
[00012518]Packet upgrade start...
[00012563]Packet checking...
[00012602]Packet vlink 01.08.0080 <-> 01.07.0060.
[00012680]Done.
[00012717]Version checking[1]...
[00012805][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012884][03 06][00] v2.4.20.28 -> v2.4.14.5
[00012934][04 00][00] v1.48.0.0 -> v1.44.0.0
[00013053][11 00][00] v1.8.0.0 -> v1.7.15.1
[00013135][12 00][00] v1.11.0.0 -> v1.10.0.0
[00013239][12 01][00] v1.11.0.0 -> v1.10.0.0
[00013341][12 02][00] v1.11.0.0 -> v1.10.0.0
[00013438][12 03][00] v1.11.0.0 -> v1.10.0.0
[00025982][15 00][00] device not detected.
[00026074][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026194][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026270][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026310][01 00][00] v1.32.5432 -> v1.30.5036
[00026350][01 01][00] v1.32.5432 -> v1.30.5036
[00038904][08 00][00] device not detected.
[00038972][09 00][00] v3.0.0.10 -> v3.0.0.10
[00039015]Packet upgrade failed at version checking.
[00012459]========== remo-con disconnect. boot(15) ============
[00012497]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0xac165731].
[00012539]Packet upgrade start...
[00012590]Packet checking...
[00012632]Packet vlink 01.08.0080 <-> 01.07.0060.
[00012703]Done.
[00012744]Version checking[1]...
[00012835][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012910][03 06][00] v2.4.20.28 -> v2.4.14.5
[00012963][04 00][00] v1.48.0.0 -> v1.44.0.0
[00013089][11 00][00] v1.8.0.0 -> v1.7.15.1
[00013179][12 00][00] v1.11.0.0 -> v1.10.0.0
[00013283][12 01][00] v1.11.0.0 -> v1.10.0.0
[00013383][12 02][00] v1.11.0.0 -> v1.10.0.0
[00013483][12 03][00] v1.11.0.0 -> v1.10.0.0
[00026025][15 00][00] device not detected.
[00026119][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026266][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026435][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026478][01 00][00] v1.32.5432 -> v1.30.5036
[00026520][01 01][00] v1.32.5432 -> v1.30.5036
[00039069][08 00][00] device not detected.
[00039130][09 00][00] v3.0.0.10 -> v3.0.0.10
[00039174]Packet upgrade failed at version checking.
[00014386]========== remo-con disconnect. boot(15) ============
[00014429]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0xac165731].
[00014469]Packet upgrade start...
[00014524]Packet checking...
[00014565]Packet vlink 01.08.0080 <-> 01.07.0060.
[00014639]Done.
[00014688]Version checking[1]...
[00014778][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014878][03 06][00] v2.4.20.28 -> v2.4.14.5
[00014936][04 00][00] v1.48.0.0 -> v1.44.0.0
[00015058][11 00][00] v1.8.0.0 -> v1.7.15.1
[00015147][12 00][00] v1.11.0.0 -> v1.10.0.0
[00015254][12 01][00] v1.11.0.0 -> v1.10.0.0
[00015354][12 02][00] v1.11.0.0 -> v1.10.0.0
[00015454][12 03][00] v1.11.0.0 -> v1.10.0.0
[00028002][15 00][00] device not detected.
[00028103][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028273][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028354][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028399][01 00][00] v1.32.5432 -> v1.30.5036
[00028441][01 01][00] v1.32.5432 -> v1.30.5036
[00040982][08 00][00] device not detected.
[00041055][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041094]Packet upgrade failed at version checking.
[00014388]========== remo-con disconnect. boot(15) ============
[00014472]Packet upgrade start...
[00014525]Packet checking...
[00014567]Packet vlink 01.08.0080 <-> 01.07.0060.
[00014650]Done.
[00014693]Version checking[1]...
[00014780][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014880][03 06][00] v2.4.20.28 -> v2.4.14.5
[00014939][04 00][00] v1.48.0.0 -> v1.44.0.0
[00015080][11 00][00] v1.8.0.0 -> v1.7.15.1
[00015194][12 00][00] v1.11.0.0 -> v1.10.0.0
[00015295][12 01][00] v1.11.0.0 -> v1.10.0.0
[00015508][12 02][00] v1.11.0.0 -> v1.10.0.0
[00015614][12 03][00] v1.11.0.0 -> v1.10.0.0
[00028164][15 00][00] device not detected.
[00028270][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028405][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028475][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028528][01 00][00] v1.32.5432 -> v1.30.5036
[00028572][01 01][00] v1.32.5432 -> v1.30.5036
[00041115][08 00][00] device not detected.
[00041197][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041243]Packet upgrade failed at version checking.
[00014403]========== remo-con disconnect. boot(0) ============
[00014447]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0xac165731].
[00014495]Packet upgrade start...
[00014543]Packet checking...
[00014587]Packet vlink 01.08.0080 <-> 01.07.0060.
[00014661]Done.
[00014705]Version checking[1]...
[00014797][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014877][03 06][00] v2.4.20.28 -> v2.4.14.5
[00015146][12 00][00] v1.11.0.0 -> v1.10.0.0
[00015251][12 01][00] v1.11.0.0 -> v1.10.0.0
[00015350][12 02][00] v1.11.0.0 -> v1.10.0.0
[00015450][12 03][00] v1.11.0.0 -> v1.10.0.0
[00028005][15 00][00] device not detected.
[00028102][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028268][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028339][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028383][01 00][00] v1.32.5432 -> v1.30.5036
[00028427][01 01][00] v1.32.5432 -> v1.30.5036
[00040975][08 00][00] device not detected.
[00041059][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041103]Packet upgrade failed at version checking.
[00016361]========== remo-con disconnect. boot(15) ============
[00016407]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x28527b69].
[00016454]Packet upgrade start...
[00016507]Packet checking...
[00016561]Packet vlink 01.08.0080 <-> 01.07.0060.
[00016645]Done.
[00016692]Version checking[1]...
[00016778][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016859][03 06][00] v2.4.20.28 -> v2.4.14.5
[00017004][04 00][00] v1.48.0.0 -> v1.44.0.0
[00017143][11 00][00] v1.8.0.0 -> v1.7.15.1
[00017243][12 00][00] v1.11.0.0 -> v1.10.0.0
[00017344][12 01][00] v1.11.0.0 -> v1.10.0.0
[00017426][12 02][00] v1.11.0.0 -> v1.10.0.0
[00017528][12 03][00] v1.11.0.0 -> v1.10.0.0
[00030076][15 00][00] device not detected.
[00030168][17 00][00] v1.1.1.7 -> v1.1.1.7
[00030305][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030384][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030432][01 00][00] v1.32.5432 -> v1.30.5036
[00030490][01 01][00] v1.32.5432 -> v1.30.5036
[00043056][08 00][00] device not detected.
[00043125][09 00][00] v3.0.0.10 -> v3.0.0.10
[00043174]Packet upgrade failed at version checking.
[00015679]========== remo-con disconnect. boot(15) ============
[00015729]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x28527b69].
[00015783]Packet upgrade start...
[00015841]Packet checking...
[00015942]Packet vlink 01.08.0080 <-> 01.07.0060.
[00015997]Done.
[00016048]Version checking[1]...
[00016142][03 05][00] v34.2.0.9 -> v34.2.0.9 need upgrade.
[00016241][03 06][00] v2.4.20.28 -> v2.4.14.5 need upgrade.
[00016300][04 00][00] v1.48.0.0 -> v1.44.0.0 need upgrade.
[00016436][11 00][00] v1.8.0.0 -> v1.7.15.1 need upgrade.
[00016530][12 00][00] v1.11.0.0 -> v1.10.0.0 need upgrade.
[00016630][12 01][00] v1.11.0.0 -> v1.10.0.0 need upgrade.
[00016730][12 02][00] v1.11.0.0 -> v1.10.0.0 need upgrade.
[00016861][12 03][00] v1.11.0.0 -> v1.10.0.0 need upgrade.
[00029416][15 00][00] device not detected.
[00029536][17 00][00] v1.1.1.7 -> v1.1.1.7 need upgrade.
[00029685][17 01][00] v1.0.2.7 -> v1.0.2.7 need upgrade.
[00029780][19 00][00] v1.0.8.96 -> v1.0.8.96 need upgrade.
[00029831][01 00][00] v1.32.5432 -> v1.30.5036 need upgrade
[00029885][01 01][00] v1.32.5432 -> v1.30.5036 need upgrade
[00042436][08 00][00] device not detected.
[00042516][09 00][00] v3.0.0.10 -> v3.0.0.10 need upgrade.
[00042572]Done.
[00044623]Waiting for user confirm...
[00054776]Timeout, start upgrade automatically.
[00054879]Firmware upgrading[1]...
[00068271][01 00] Firmware upgrade start...
[00014245][01 00] Firmware upgrade finished successfully.
[00014302]Done.
[00014364]Packet [C:\P3X_FW_V01.08.0080.bin] resumed, card sn [0x28527b69].
[00014438]Packet vlink 01.08.0080 <-> 01.07.0060.
[00014492]Version checking[2]...
[00014585][03 05][00] v34.2.0.9 -> v34.2.0.9 need upgrade.
[00014685][03 06][00] v2.4.20.28 -> v2.4.14.5 need upgrade.
[00014749][04 00][00] v1.48.0.0 -> v1.44.0.0 need upgrade.
[00014903][11 00][00] v1.8.0.0 -> v1.7.15.1 need upgrade.
[00015013][12 00][00] v1.11.0.0 -> v1.10.0.0 need upgrade.
[00015137][12 01][00] v1.11.0.0 -> v1.10.0.0 need upgrade.
[00015252][12 02][00] v1.11.0.0 -> v1.10.0.0 need upgrade.
[00015352][12 03][00] v1.11.0.0 -> v1.10.0.0 need upgrade.
[00027905][15 00][00] device not detected.
[00028007][17 00][00] v1.1.1.7 -> v1.1.1.7 need upgrade.
[00028148][17 01][00] v1.0.2.7 -> v1.0.2.7 need upgrade.
[00028218][19 00][00] v1.0.8.96 -> v1.0.8.96 need upgrade.
[00028282][01 00][05] v1.30.5036 -> v1.30.5036 need upgrade
[00028336][01 01][00] v1.32.5432 -> v1.30.5036 need upgrade
[00040889][08 00][00] device not detected.
[00040959][09 00][00] v3.0.0.10 -> v3.0.0.10 need upgrade.
[00041014]Done.
[00041070]Firmware upgrading[2]...
[00041242][01 01] Firmware upgrade start...
[00071575][01 01] Firmware upgrade finished successfully.
[00071650][12 00] Firmware upgrade start...
[00130073][12 00] Firmware upgrade finished successfully.
[00130144][12 01] Firmware upgrade start...
[00188608][12 01] Firmware upgrade finished successfully.
[00188677][12 02] Firmware upgrade start...
[00247546][12 02] Firmware upgrade finished successfully.
[00247614][12 03] Firmware upgrade start...
[00309182][12 03] Firmware upgrade finished successfully.
[00309262][17 00] Firmware upgrade start...
[00385706][17 00] Firmware upgrade finished successfully.
[00385889][17 01] Firmware upgrade start...
[00445157][17 01] Firmware upgrade finished successfully.
[00445221][11 00] Firmware upgrade start...
[00494584][11 00] Firmware upgrade finished successfully.
[00494656][03 05] Firmware upgrade start...
[00567203][03 05] Firmware upgrade finished successfully.
[00567484][03 06] Firmware upgrade start...
[00909567][03 06] Firmware upgrade finished successfully.
[00912791][19 00] Firmware upgrade start...
[00923145][19 00] stop streaming timeout, continue upgrade.
[01073221][19 00] start streaming timeout, continue upgrade.
[01103276][19 00] Firmware upgrade finished successfully.
[01103367][09 00] Firmware upgrade start...
[01155543][09 00] Firmware upgrade finished successfully.
[01155632][04 00] Firmware upgrade start...
[01215168][04 00] Firmware upgrade finished successfully.
[01215226]Done.
[01215278]Version checking[3]...
[01215365][03 05][05] v34.2.0.9 -> v34.2.0.9 need upgrade.
[01215446][03 06][05] v2.4.14.5 -> v2.4.14.5 need upgrade.
[01215518][04 00][05] v1.44.0.0 -> v1.44.0.0 need upgrade.
[01215645][11 00][05] v1.7.15.1 -> v1.7.15.1 need upgrade.
[01215736][12 00][05] v1.10.0.0 -> v1.10.0.0 need upgrade.
[01215835][12 01][05] v1.10.0.0 -> v1.10.0.0 need upgrade.
[01215934][12 02][05] v1.10.0.0 -> v1.10.0.0 need upgrade.
[01216039][12 03][05] v1.10.0.0 -> v1.10.0.0 need upgrade.
[01228598][15 00][00] device not detected.
[01228700][17 00][05] v1.1.1.7 -> v1.1.1.7 need upgrade.
[01228835][17 01][05] v1.0.2.7 -> v1.0.2.7 need upgrade.
[01228912][19 00][05] v1.0.8.96 -> v1.0.8.96 need upgrade.
[01228974][01 00][05] v1.30.5036 -> v1.30.5036 need upgrade
[01229032][01 01][05] v1.30.5036 -> v1.30.5036 need upgrade
[01241586][08 00][00] device not detected.
[01241651][09 00][05] v3.0.0.10 -> v3.0.0.10 need upgrade.
[01241703]Packet upgrade failed at version checking.
[00961994]========== 2017.04.10 15:08:37. boot(15) ============
[00962051]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x28527b69].
[00962223]Packet upgrade start...
[00962309]Packet checking...
[00962372]Packet vlink 01.08.0080 <-> 01.07.0060.
[00962430]Done.
[00962485]Version checking[1]...
[00962585][03 05][00] v34.2.0.9 -> v34.2.0.9 need upgrade.
[00962690][03 06][00] v2.4.14.5 -> v2.4.14.5 need upgrade.
[00962755][04 00][00] v1.44.0.0 -> v1.44.0.0 need upgrade.
[00962905][11 00][00] v1.7.15.1 -> v1.7.15.1 need upgrade.
[00963014][12 00][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00963139][12 01][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00963265][12 02][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00963374][12 03][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00975931][15 00][00] device not detected.
[00976051][17 00][00] v1.1.1.7 -> v1.1.1.7 need upgrade.
[00976192][17 01][00] v1.0.2.7 -> v1.0.2.7 need upgrade.
[00976283][19 00][00] v1.0.8.96 -> v1.0.8.96 need upgrade.
[00976339][01 00][00] v1.30.5036 -> v1.30.5036 need upgrade
[00976396][01 01][00] v1.30.5036 -> v1.30.5036 need upgrade
[00988962][08 00][00] device not detected.
[00989044][09 00][00] v3.0.0.10 -> v3.0.0.10 need upgrade.
[00989101]Done.
[00991164]Waiting for user confirm...
[01001219]Timeout, start upgrade automatically.
[01001341]Firmware upgrading[1]...
[01014344][01 00] Firmware upgrade start...
[00014248][01 00] Firmware upgrade finished successfully.
[00014307]Done.
[00014370]Packet [C:\P3X_FW_V01.08.0080.bin] resumed, card sn [0x28527b69].
[00014450]Packet vlink 01.08.0080 <-> 01.07.0060.
[00014508]Version checking[2]...
[00014604][03 05][00] v34.2.0.9 -> v34.2.0.9 need upgrade.
[00014704][03 06][00] v2.4.14.5 -> v2.4.14.5 need upgrade.
[00014770][04 00][00] v1.44.0.0 -> v1.44.0.0 need upgrade.
[00014904][11 00][00] v1.7.15.1 -> v1.7.15.1 need upgrade.
[00015025][12 00][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00015133][12 01][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00015233][12 02][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00015333][12 03][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00027998][15 00][00] device not detected.
[00028095][17 00][00] v1.1.1.7 -> v1.1.1.7 need upgrade.
[00028234][17 01][00] v1.0.2.7 -> v1.0.2.7 need upgrade.
[00028310][19 00][00] v1.0.8.96 -> v1.0.8.96 need upgrade.
[00028370][01 00][05] v1.30.5036 -> v1.30.5036 need upgrade
[00028431][01 01][00] v1.30.5036 -> v1.30.5036 need upgrade
[00040988][08 00][00] device not detected.
[00041063][09 00][00] v3.0.0.10 -> v3.0.0.10 need upgrade.
[00041122]Done.
[00041181]Firmware upgrading[2]...
[00041362][01 01] Firmware upgrade start...
[00071700][01 01] Firmware upgrade finished successfully.
[00071772][12 00] Firmware upgrade start...
[00133171][12 00] Firmware upgrade finished successfully.
[00133249][12 01] Firmware upgrade start...
[00196079][12 01] Firmware upgrade finished successfully.
[00196158][12 02] Firmware upgrade start...
[00255904][12 02] Firmware upgrade finished successfully.
[00255983][12 03] Firmware upgrade start...
[00316026][12 03] Firmware upgrade finished successfully.
[00316111][17 00] Firmware upgrade start...
[00394170][17 00] Firmware upgrade finished successfully.
[00394240][17 01] Firmware upgrade start...
[00463414][17 01] Firmware upgrade finished successfully.
[00463483][11 00] Firmware upgrade start...
[00512787][11 00] Firmware upgrade finished successfully.
[00512861][03 05] Firmware upgrade start...
[00583770][03 05] Firmware upgrade finished successfully.
[00584034][03 06] Firmware upgrade start...
[00915144][03 06] Firmware upgrade finished successfully.
[00918111][19 00] Firmware upgrade start...
[00928467][19 00] stop streaming timeout, continue upgrade.
[01078978][19 00] start streaming timeout, continue upgrade.
[01109035][19 00] Firmware upgrade finished successfully.
[01109119][09 00] Firmware upgrade start...
[01161294][09 00] Firmware upgrade finished successfully.
[01161380][04 00] Firmware upgrade start...
[01220914][04 00] Firmware upgrade finished successfully.
[01220971]Done.
[01221148]Version checking[3]...
[01221245][03 05][05] v34.2.0.9 -> v34.2.0.9 need upgrade.
[01221326][03 06][05] v2.4.14.5 -> v2.4.14.5 need upgrade.
[01221387][04 00][05] v1.44.0.0 -> v1.44.0.0 need upgrade.
[01221524][11 00][05] v1.7.15.1 -> v1.7.15.1 need upgrade.
[01221614][12 00][05] v1.10.0.0 -> v1.10.0.0 need upgrade.
[01221714][12 01][05] v1.10.0.0 -> v1.10.0.0 need upgrade.
[01221815][12 02][05] v1.10.0.0 -> v1.10.0.0 need upgrade.
[01221913][12 03][05] v1.10.0.0 -> v1.10.0.0 need upgrade.
[01234478][15 00][00] device not detected.
[01234570][17 00][05] v1.1.1.7 -> v1.1.1.7 need upgrade.
[01234716][17 01][05] v1.0.2.7 -> v1.0.2.7 need upgrade.
[01234797][19 00][05] v1.0.8.96 -> v1.0.8.96 need upgrade.
[01234861][01 00][05] v1.30.5036 -> v1.30.5036 need upgrade
[01234919][01 01][05] v1.30.5036 -> v1.30.5036 need upgrade
[01247481][08 00][00] device not detected.
[01247556][09 00][05] v3.0.0.10 -> v3.0.0.10 need upgrade.
[01247616]Packet upgrade failed at version checking.
[00015876]========== 2017.04.11 18:31:56. boot(15) ============
[00015931]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x28527b69].
[00015991]Packet upgrade start...
[00016074]Packet checking...
[00016142]Packet vlink 01.08.0080 <-> 01.07.0060.
[00016197]Done.
[00016262]Version checking[1]...
[00016358][03 05][00] v34.2.0.9 -> v34.2.0.9 need upgrade.
[00016438][03 06][00] v2.4.14.5 -> v2.4.14.5 need upgrade.
[00016502][04 00][00] v1.44.0.0 -> v1.44.0.0 need upgrade.
[00016644][11 00][00] v1.7.15.1 -> v1.7.15.1 need upgrade.
[00016748][12 00][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00016847][12 01][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00016948][12 02][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00017051][12 03][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00029620][15 00][00] device not detected.
[00029728][17 00][00] v1.1.1.7 -> v1.1.1.7 need upgrade.
[00029889][17 01][00] v1.0.2.7 -> v1.0.2.7 need upgrade.
[00029960][19 00][00] v1.0.8.96 -> v1.0.8.96 need upgrade.
[00030126][01 00][00] v1.30.5036 -> v1.30.5036 need upgrade
[00030188][01 01][00] v1.30.5036 -> v1.30.5036 need upgrade
[00042745][08 00][00] device not detected.
[00042845][09 00][00] v3.0.0.10 -> v3.0.0.10 need upgrade.
[00042906]Done.
[00044971]Waiting for user confirm...
[00055027]Timeout, start upgrade automatically.
[00055153]Firmware upgrading[1]...
[00068293][01 00] Firmware upgrade start...
[00014244][01 00] Firmware upgrade finished successfully.
[00014310]Done.
[00014378]Packet [C:\P3X_FW_V01.08.0080.bin] resumed, card sn [0x28527b69].
[00014462]Packet vlink 01.08.0080 <-> 01.07.0060.
[00014520]Version checking[2]...
[00014616][03 05][00] v34.2.0.9 -> v34.2.0.9 need upgrade.
[00014716][03 06][00] v2.4.14.5 -> v2.4.14.5 need upgrade.
[00014784][04 00][00] v1.44.0.0 -> v1.44.0.0 need upgrade.
[00014935][11 00][00] v1.7.15.1 -> v1.7.15.1 need upgrade.
[00015049][12 00][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00015176][12 01][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00015309][12 02][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00015435][12 03][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00028006][15 00][00] device not detected.
[00028100][17 00][00] v1.1.1.7 -> v1.1.1.7 need upgrade.
[00028245][17 01][00] v1.0.2.7 -> v1.0.2.7 need upgrade.
[00028320][19 00][00] v1.0.8.96 -> v1.0.8.96 need upgrade.
[00028381][01 00][05] v1.30.5036 -> v1.30.5036 need upgrade
[00028446][01 01][00] v1.30.5036 -> v1.30.5036 need upgrade
[00041021][08 00][00] device not detected.
[00041100][09 00][00] v3.0.0.10 -> v3.0.0.10 need upgrade.
[00041162]Done.
[00041226]Firmware upgrading[2]...
[00041405][01 01] Firmware upgrade start...
[00071745][01 01] Firmware upgrade finished successfully.
[00071825][12 00] Firmware upgrade start...
[00132387][12 00] Firmware upgrade finished successfully.
[00132463][12 01] Firmware upgrade start...
[00192898][12 01] Firmware upgrade finished successfully.
[00192974][12 02] Firmware upgrade start...
[00251953][12 02] Firmware upgrade finished successfully.
[00252036][12 03] Firmware upgrade start...
[00311203][12 03] Firmware upgrade finished successfully.
[00311292][17 00] Firmware upgrade start...
[00387740][17 00] Firmware upgrade finished successfully.
[00387812][17 01] Firmware upgrade start...
[00445564][17 01] Firmware upgrade finished successfully.
[00445637][11 00] Firmware upgrade start...
[00492499][11 00] Firmware upgrade finished successfully.
[00492578][03 05] Firmware upgrade start...
[00561702][03 05] Firmware upgrade finished successfully.
[00561969][03 06] Firmware upgrade start...
[00901494][03 06] Firmware upgrade finished successfully.
[00904591][19 00] Firmware upgrade start...
[00914959][19 00] stop streaming timeout, continue upgrade.
[01065084][19 00] start streaming timeout, continue upgrade.
[01095145][19 00] Firmware upgrade finished successfully.
[01095233][09 00] Firmware upgrade start...
[01150381][09 00] Firmware upgrade finished successfully.
[01150476][04 00] Firmware upgrade start...
[01210021][04 00] Firmware upgrade finished successfully.
[01210081]Done.
[01210148]Version checking[3]...
[01210240][03 05][05] v34.2.0.9 -> v34.2.0.9 need upgrade.
[01210339][03 06][05] v2.4.14.5 -> v2.4.14.5 need upgrade.
[01210409][04 00][05] v1.44.0.0 -> v1.44.0.0 need upgrade.
[01210539][11 00][05] v1.7.15.1 -> v1.7.15.1 need upgrade.
[01210648][12 00][05] v1.10.0.0 -> v1.10.0.0 need upgrade.
[01210754][12 01][05] v1.10.0.0 -> v1.10.0.0 need upgrade.
[01210884][12 02][05] v1.10.0.0 -> v1.10.0.0 need upgrade.
[01210989][12 03][05] v1.10.0.0 -> v1.10.0.0 need upgrade.
[01223552][15 00][00] device not detected.
[01223652][17 00][05] v1.1.1.7 -> v1.1.1.7 need upgrade.
[01223790][17 01][05] v1.0.2.7 -> v1.0.2.7 need upgrade.
[01223890][19 00][05] v1.0.8.96 -> v1.0.8.96 need upgrade.
[01223954][01 00][05] v1.30.5036 -> v1.30.5036 need upgrade
[01224017][01 01][05] v1.30.5036 -> v1.30.5036 need upgrade
[01236584][08 00][00] device not detected.
[01236766][09 00][05] v3.0.0.10 -> v3.0.0.10 need upgrade.
[01236834]Packet upgrade failed at version checking.
[00015953]========== 2017.04.12 13:41:22. boot(15) ============
[00016013]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x28527b69].
[00016076]Packet upgrade start...
[00016147]Packet checking...
[00016214]Packet vlink 01.10.0090 <-> 01.10.0090.
[00016278]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00016346]Done.
[00016412]Version checking[1]...
[00016518][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016641][03 06][00] v2.4.14.5 -> v2.4.20.28 need upgrade.
[00016710][04 00][00] v1.44.0.0 -> v1.48.0.0 need upgrade.
[00016859][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016997][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00017055][11 01][00] v1.8.0.0 -> v2.0.0.33
[00017178][12 00][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00017277][12 01][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00017411][12 02][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00017510][12 03][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00030077][15 00][00] device not detected.
[00030188][17 00][00] v1.1.1.7 -> v1.1.1.7
[00030328][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030415][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030478][01 00][00] v1.30.5036 -> v1.32.5432 need upgrade
[00030550][01 01][00] v1.30.5036 -> v1.32.5432 need upgrade
[00043118][08 00][00] device not detected.
[00043208][09 00][00] v3.0.0.10 -> v3.0.0.10
[00043271]Done.
[00045340]Waiting for user confirm...
[00055402]Timeout, start upgrade automatically.
[00055525]Firmware upgrading[1]...
[00067883][01 00] Firmware upgrade start...
[00014255][01 00] Firmware upgrade finished successfully.
[00014322]Done.
[00014393]Packet [C:\P3X_FW_V01.10.0090.bin] resumed, card sn [0x28527b69].
[00014465]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014528]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00014591]Version checking[2]...
[00014710][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014930][03 06][00] v2.4.14.5 -> v2.4.20.28 need upgrade.
[00015001][04 00][00] v1.44.0.0 -> v1.48.0.0 need upgrade.
[00015151][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015291][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015354][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015470][12 00][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00015604][12 01][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00015738][12 02][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00015858][12 03][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00028432][15 00][00] device not detected.
[00028535][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028705][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028785][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028853][01 00][05] v1.32.5432 -> v1.32.5432
[00028918][01 01][00] v1.30.5036 -> v1.32.5432 need upgrade
[00041484][08 00][00] device not detected.
[00041610][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041683]Done.
[00041746]Firmware upgrading[2]...
[00016248]========== remo-con disconnect. boot(15) ============
[00016318]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x28527b69].
[00016382]Packet upgrade start...
[00016474]Packet checking...
[00016538]Packet vlink 01.10.0090 <-> 01.10.0090.
[00016603]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00016671]Done.
[00016740]Version checking[1]...
[00016837][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016937][03 06][00] v2.4.14.5 -> v2.4.20.28 need upgrade.
[00017008][04 00][00] v1.44.0.0 -> v1.48.0.0 need upgrade.
[00017151][11 00][00] v1.8.0.0 -> v1.8.0.0
[00017291][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00017356][11 01][00] v1.8.0.0 -> v2.0.0.33
[00017465][12 00][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00017565][12 01][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00017665][12 02][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00017767][12 03][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00030328][15 00][00] device not detected.
[00030441][17 00][00] v1.1.1.7 -> v1.1.1.7
[00030681][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030762][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030827][01 00][00] v1.32.5432 -> v1.32.5432
[00030896][01 01][00] v1.30.5036 -> v1.32.5432 need upgrade
[00043462][08 00][00] device not detected.
[00043555][09 00][00] v3.0.0.10 -> v3.0.0.10
[00043616]Done.
[00045690]Waiting for user confirm...
[00055753]Timeout, start upgrade automatically.
[00055890]Firmware upgrading[1]...
[00056052][01 01] Firmware upgrade start...
[00086361][01 01] Firmware upgrade finished successfully.
[00086449][12 00] Firmware upgrade start...
[00150055][12 00] Firmware upgrade finished successfully.
[00150137][12 01] Firmware upgrade start...
[00212238][12 01] Firmware upgrade finished successfully.
[00212318][12 02] Firmware upgrade start...
[00275341][12 02] Firmware upgrade finished successfully.
[00275429][12 03] Firmware upgrade start...
[00341294][12 03] Firmware upgrade finished successfully.
[00341566][03 06] Firmware upgrade start...
[00728400][03 06] Firmware upgrade finished successfully.
[00728493][04 00] Firmware upgrade start...
[00787143][04 00] Firmware upgrade finished successfully.
[00787210]Done.
[00787279]Version checking[2]...
[00787374][03 05][00] v34.2.0.9 -> v34.2.0.9
[00787510][03 06][05] v2.4.20.28 -> v2.4.20.28
[00787582][04 00][05] v1.48.0.0 -> v1.48.0.0
[00787731][11 00][00] v1.8.0.0 -> v1.8.0.0
[00787876][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00787948][11 01][00] v1.8.0.0 -> v2.0.0.33
[00788069][12 00][05] v1.11.0.0 -> v1.11.0.0
[00788229][12 01][05] v1.11.0.0 -> v1.11.0.0
[00788339][12 02][05] v1.11.0.0 -> v1.11.0.0
[00788444][12 03][05] v1.11.0.0 -> v1.11.0.0
[00801011][15 00][00] device not detected.
[00801119][17 00][00] v1.1.1.7 -> v1.1.1.7
[00801259][17 01][00] v1.0.2.7 -> v1.0.2.7
[00801339][19 00][00] v1.0.8.96 -> v1.0.8.96
[00801407][01 00][00] v1.32.5432 -> v1.32.5432
[00801478][01 01][05] v1.32.5432 -> v1.32.5432
[00814041][08 00][00] device not detected.
[00814241][09 00][00] v3.0.0.10 -> v3.0.0.10
[00814309]Packet upgrade failed at version checking.
2017-4-13
