Hello I have just got my inspire and new to this stuff, I have flown it once today and now trying to install the new firmware up date in to the aircraft as it prompted me to do so.
The up date stopped and in the results file it said firmware the same as in stalled on the inspire. Since this I can not link the control to the aircraft. The difficulty is I am way in a hotel and can not get it into travel mode to pack it away. Please help
Why don't we know the function of this screw? Is it documented anywhere? DJI Europe gave me a useful hint.
There is a screw beneath this hole. Turn it counterclockwise with a slotted screwdriver.
The arms will go up to travel mode and you can ship the aircraft with the original case.
Yes, You have to update your RC also - after the update it could be, that you have to link the rc again with your I1 (Binding mode in app and button on the front of the inspire...)
Hope this works...
panox Posted at 2015-3-4 02:45
Why don't we know the function of this screw? Is it documented anywhere? DJI Europe gave me a usef ...
No connection link between RC and aircraft after firmware update. Have to drive 30 km today with my Inspire. I can not force it to go to travel mode, even after adjusting this screw manually (no reaction discovered at all). I suppose the Aircraft should be powered up before this step, Panox?
post Posted at 2015-4-6 15:18
No connection link between RC and aircraft after firmware update. Have to drive 30 km today with m ...
Adjusted the screw while Aircraft was not powered. Had to allow several rotations CC to see that the legs was moving into travel mode position. Good to know
