Mavic RAW files on Apple Mac
12
15205 77 2017-4-21
BeachDuc
Flight distance : 29544 ft
Ex Machina Posted at 2017-5-16 09:59
How bout posting the full EXIF data from new DNGs when you get a chance? Would be interesting to compare.
Here you go:
Aperture Value: 2.27
Body Serial Number: 2016041101
CFA Pattern: 0, 1, 1, 2
Contrast: Normal
Custom Rendered: Normal process
Date Time Digitized: 17 May 2017, 10:29:42 am
Date Time Original: 17 May 2017, 10:29:42 am
Digital Zoom Ratio: 0
Exif Version: 2.3
Exposure Bias Value: 0
Exposure Mode: Auto exposure
Exposure Program: Normal program
Exposure Time: 1/480
File Source: DSC
Flash: No flash function
FNumber: 2.2
Focal Length: 4.73
Focal Length In 35mm Film: 26
Gain Control: None
Photographic Sensitivity (ISO): 100
Lens Specification: 26.3, 26.3, 2.2, 2.2
Light Source: unknown
Max Aperture Value: 2.27
Metering Mode: CenterWeightedAverage
Saturation: Normal
Scene Capture Type: Standard
Scene Type: A directly photographed image
Sharpness: Normal
Shutter Speed Value: 1/480
Subject Distance: 0
Subject Distance Range: unknown
White Balance: Auto white balance
Lens Info: 26.3, 26.3, 2.2, 2.2
Lens Model: 26.3 mm f/2.2
Color Model: RGB
Depth: 16
Orientation: 1 (Normal)
Pixel Height: 2,992
Pixel Width: 3,992
Profile Name: Adobe RGB (1998)
DNG Backward Version: 1.3
DNG Version: 1.4
Unique Camera Model: FC220
Altitude: 58.9 m (193.25 ft)
Altitude Reference: below sea level
GPS Version: 2.3.0.0
Latitude: 33° 7’ 6.06” S
Longitude: 151° 38’ 53.538” E
The DNG was straight off the SD card and the data from the various tabs in the inspector page of Preview.
2017-5-16
BeachDuc
Here's a link to the new photo, in my DropBox: https://www.dropbox.com/s/ob5cmzpch0njfmz/DJI_0002.DNG?dl=0
2017-5-16
Ex Machina
Flight distance : 1806362 ft
BeachDuc Posted at 2017-5-16 22:40
Looks like the same kMDItemCreator version as your original Mavic, so I guess it really was just a weirdo one-off problem rather than a production run problem. Glad you got it sorted!
2017-5-17
HeadOn
Flight distance : 1903835 ft
Ex Machina Posted at 2017-5-17 06:00
Looks like it isn't exactly a one-off, since my Mavic began exhibiting this exact same problem after the latest firmware update a week or so ago.  Prior to that, DNG files were correctly formatted and working. Ever since the firmware update however,  I am seeing the exact same symptoms as the original poster.
I'll reach out to DJI this week and see what they say.  I'm grateful for this thread and hope that it will help me explain this to DJI for a quick resolution.  I've started to really enjoy and rely on the the RAW capabilities of my Mavic and really want that back.
2017-6-18
Flyrmyr
HeadOn Posted at 2017-6-18 12:05
HeadOn, were you able to solve this issue? I've been having very similar problems and would love to know how to get RAW photos working in Apple Photos.
2017-6-25
LtCarter47
Oh wow am I glad I found this thread!  I also started having this issue with a recent firmware update!  It has been very frustrating to troubleshoot and I almost gave up and started paying for Lightroom!  I guess I will open a support ticket with DJI and see what happens!  Thank you guys!
2017-6-30
Steve Medwin
Flight distance : 288934 ft
Interesting thread. I'm having the same problems with DNG files from my Mavic on my iMac running Sierra v10.12.5 but they are working fine on my MacBook Air running Sierra v 10.12.3.  The .5 update adds support for more RAW formats but can't imagine why it would break old support, even though no DJI cameras are listed.
I've been going back and forth with DJI and nothing they have suggested makes any difference. Has anyone reached out to Apple?
BTW, the Adobe DNG Converter (v9.10) doesn't fix this issue.
Steve
2017-7-2
fansd4bc2ddd
I have the same problem that DNG files in the MBP do not open in preview. This incident came up with the latest update.
2017-7-2
Ex Machina
Steve Medwin Posted at 2017-7-2 07:42
Your issue is different from the OP's incomplete meta data issue.
You would think that if the most recent MacOS RAW file support update was the problem then DNG shot with .0700 and earlier would also be affected, but they are not. Therefore, it seems the difference is in the way .0800/.0900 writes DNG.
2017-7-2
Ex Machina
Ex Machina Posted at 2017-7-2 09:11
New info: DNG from .0900 work fine on my MacBook Pro running El Capitan, both in Finder Quick Look, previews and Preview. So the issue appears much more complex than I originally thought. I'm tracking my research of the issue in this thread.
2017-7-2
mazimoose
Flight distance : 906 ft
I'm facing the same issue as Steve Medwin and others. The DNG files on the Mac shows up as a fully black image for me (Preview app and Photos app).
I'm running Mac OS X Sierra 10.12.5. My laptop is MacBook Pro (Retina, 13-inch, Early 2015). Firmware v01.03.0900.
I've also contacted DJI via e-mail.
2017-7-2
Ex Machina
mazimoose Posted at 2017-7-2 09:41
I've figured it out, it's a conflict between the last two Mavic firmware releases and the version of Raw Camera Support in MacOS 10.12.5, see my summary post.
2017-7-2
mazimoose
Ex Machina Posted at 2017-7-2 15:56
Yeah, I saw your post. Great investigative work. Hoping DJI/Apple will take action asap.
2017-7-2
Ex Machina
mazimoose Posted at 2017-7-2 16:50
Thanks, me, too.
2017-7-2
DooMMasteR
Flight distance : 38891 ft
This issue persists and the DJI support seems to be unaware of it.
2017-7-12
JuvbVuWUcCYy
Flight distance : 1440 ft
Thankful I found this thread. I am having the exact same issue, only recently started using raw image and can't open them in Photos , they are not recognized by Affinity Photo either. Is this being tracked somewhere for resolution?
2017-7-21
fans3cc4b3f6
Flight distance : 28100 ft
JuvbVuWUcCYy Posted at 2017-7-21 12:31
Same issue here, anyone find a solve?
This is becoming very frustrating.
2017-8-1
RCkable5
Flight distance : 427684 ft
Just want to be added to the "Me too" list.  Sometimes iPhotos will open the DNG but go black within a blink of an eye but most of the time its just a black screen.
Sierra 10.12.6. Photos 2.0
2017-8-6
Matt-M
Ditto.  No firmware update to fix this yet?  Filing a support case.
2017-8-11
drewaz
Flight distance : 99163 ft
RCkable5 Posted at 2017-8-6 07:57
I download DNG images to my iMac desk top (not photos app) and open them in photoshop elements ....  no problems at all
2017-8-11
Matt-M
drewaz Posted at 2017-8-11 14:59
Mine will not open in Adobe DNG convertor, but have not tried directly in other Adobe apps.  Will try.
2017-8-12
fans5b76c4a2
Flight distance : 240135 ft
I have been having this issue for months and would have thought either Apple or DJI would have fixed the problem. I spoke for a long time with Apple today until they said...... talk to DJI. Same scenario as many of you where mine use to work until updating the software on my MacBook Pro 2015 model system with the latest OS Sierra. Didn't make a big deal out of it as I would use Lightroom to edit my photo's anyway but tired of Not being able to view them at first via my Mac viewer. I've even tried downloading that Adobe converter but NO Help! I guess I have to make a claim to DJI as well.
2017-8-13
BeachDuc
Anybody been brave enough to try the new firmware (.1000)?  The release notes sound like they address our issue.  Mine is working fine on .0700 and I can't roll back to that, if something goes wrong, so I'll wait for positive feedback before I take the plunge!
2017-8-22
Ex Machina
BeachDuc Posted at 2017-8-22 13:30
Planning on trying it when I get home tonight. Keeping my fingers crossed. ;)
2017-8-22
BeachDuc
Ex Machina Posted at 2017-8-22 13:51
Good luck! I hope it goes smoothly.
2017-8-22
Ex Machina
BeachDuc Posted at 2017-8-22 14:00
Sadly, it did not. The black screen problem with the Finder, Preview, and presumably Photos/Aperture remain. I'm guessing they found and fixed the corruption problem, but not the MacOS compatibility issue. Works fine in Lightroom.
2017-8-22
BeachDuc
Ex Machina Posted at 2017-8-22 16:03
Thanks for the feedback and being the guinea-pig.  I'll be sticking with .0700 a bit longer then.
2017-8-22
Mermaid974
Hi everyone! Same issue. Not sure this is very helpful but until I see a fix for the firmware this is what I am doing: download the DNG on my Mac. I cannot open them with Preview or Photos.
But then I use the Adobe Digital Negative Converter and section 4, I have tried to change the Compatibility Camera raw. and Downgrading it to 4.6 is working for me.
I know it's not great to download to a lower version but at least I can import them as DNG in my Photos library.
2017-8-24
Juarez
Flight distance : 474232 ft
Hi Guys,
I'm having this same problem.
The Adobe converter at 4.6 works for me too.
Any further resolution here?
2017-9-5
Ex Machina
Juarez Posted at 2017-9-5 09:02
Hi Guys,
No change AFAIK. High Sierra, the next MacOS major version is due out this month -- I'm half-inclined to install the public beta on my laptop to see if the issue still exists.
2017-9-5
Ex Machina
Ex Machina Posted at 2017-9-5 12:17
The issue is no longer a problem on the latest public beta of High Sierra.
2017-9-5
BeachDuc
Anybody brave enough to try the new firmware and see if it solves this issue?  (I'm not on the Mac OS beta so am waiting for the official release).
2017-9-23
BeachDuc
OK I'll answer my own question.  In a rsh moment I have upgraded to 01.04.000 and thankfully the RAW photos are working as expected on Mac OS High Sierra.  Thanks goodness!
2017-10-7
Ste_427
Flight distance : 530692 ft
Hi guys,
I've the same problem with my Mavic Air.
I've tired several programs (even buying them) no chance to open those dng files.
My Mac is a new MacBook Pro 2017, fully updated, Hig Sierra installed. Mavic Air is up to date to the latest version too.
How did you solve the problem? I need to contact DJI?
Thanks
2018-2-17
djiuser_V94cV1de4G9g
Ste_427 Posted at 2018-2-17 22:52
Hi guys,
Ste_497 any update on your issue? Having the same issue with my Mavic Air and my old MacBook Pro running latest Version of El Capitan. No chance to open dng files in finder. However with Affinity photo I’m able to open the dng files from the Mavic Air. Adobe RAW Converter does not work. Would be glad to hear you have solved your issue ( and how).
2018-2-24
Ste_427
djiuser_V94cV1de4G9g Posted at 2018-2-24 23:55
Unfortunately not, for the moment.
I've contacted DJI and sent them some examples, but still no good news. They said that my problem would have been reported to application engineers and then let me know something more.
Maybe there will be a firmware update because my understanding is that this problem is very common for Mac users.
I'll try Affinity photo, thanks for the advice, i don't know it!
2018-2-26
djiuser_IBp5CPHw2eJd
Ste_427 Posted at 2018-2-26 03:49
I have the same problem and I am using 10.12.6 Sierra, and just got my Mavic Pro, but I am not using the newest firmware update.  I rolled it back so I could edit the parameters to get rid of the NFZ limits and such.
I did find that the free photo editor  GIMP does open the DNG files.
Its a pretty extensive editor also.
https://www.gimp.org/downloads/
Open source software.
2018-4-28
GIMP photo editor is free and opens the DNG images for editing.   But, I have the same problem as you with Preview, Photos, and  Graphic Convertor 9 not opening them other than just plan black images appear.
2018-4-28
12
