I start the inspire and the gimbal does nothing
831 4 2017-4-23
fans2b56e667
Flight distance : 606152 ft
Chile
I start the inspire and the gimbal does nothing!, Just turn on the green light. Everything worked fine, turn off the drone, then turned it on and no longer answered the gimbal anymore.
Download the latest firmware 01.10.01.40 and put it in the micro sd the .bin, but nothing happens either. (With the battery at 100%, the drone did not hit or anything.
2017-4-23
SkyHigh UAV
Flight distance : 2838921 ft
Needs to go in for repair, had the same issue and was told its the magnets in the gimball.
2017-5-5
Barker Flyer
Flight distance : 158327 ft
Hi,
Have you removed it and made sure it's fitted correctly?
Another thing you may want to try is a calibration in the app.
I had a similar thing happen to me and doing the above seemed to sort things out.
Cheers,
Rafael..
2017-5-5
DJI-Jamie
Flight distance : 112405 ft
As previously mentioned, have you made sure the gimbal connections are fitted properly? Did you notice this after updating firmware or did this just to seem to happen randomly?
2017-5-5
RichJ53
Flight distance : 1837356 ft
Remove the camera from the mount and clean the contacts with some good quality electrical product. I have a link below.  Also, make sure the cables connected to the mounting board are tight (sometimes these can become disconnected)   DeoxIT Liquid
link
Improves Conductivity
• Deoxidizes, Cleans & Preserves
• Reduces Intermittent Connections, Arcing & RFI
• Temperature Range, -34oC to 200oC
I hope you get things going again
Rich
2017-5-5
