skyvideoct
Flight distance : 1136230 ft
Since this is under "Pro" tree, I will post this thread since it affects all elements of "configuration" of DJI and other elements. In preface, I will acknowledge that certain proprietary elements are not available. Interfaces require a coordinated efforts and diagrams. The following is a "beginning list" of wiring diagrams required to complete a typical project:
1) pinning diagrams for each interface cable desiganted with a DJI part number.
2) pinning diagram for each "port" on any DJI component.
a- LightBridge 2
b- Flight Controller
c- Landing Gear
d- Gimbal
e- Camera
I will use as an example my intention to add a FLIR Duo-R. There is no readily available information regarding implementing the interface between the camera and LB2. I need to make a custom extended cable to allow connection and without any basic information am left SOL. This is not an acceptable blackout of information required to create, test, and implement interfaces to the basic wiring requirements of a device(s). I am also looking at the viability of certain intermediate interface blocks to support variable conditions. Again, SOL
