fanseaa83cd7
I can give you some good feedback on these props. I have put about 50 hours of use on them and they work great. They are bolted on and will not come off. I do have a few issues but it is not with the props but other variables: #1 The screws that hold on the old quick release hubs and the new props ARE A BITCH TO TAKE OFF!!! DJI has a lot of loctite on the threads so it takes some skill getting off the screws. I understand DJI's concern about the screws but keep in mind that the springs on the stock hubs recommend replacement every 30 flights. PM me if you want info on the screw removal. #2 I bought a custom case for the I2 and once I mounted the new props, I had to cut out some foam to make the I2 fit with the new goodies.
With that being said, the props are very stiff so it gives the I2 a bit more zip. I have not seen any lack of performance with the props. |
