Aardvark
Flight distance : 384432 ft
I've seen the '+' mentioned in one other thread, there seemed to be no definitive answer. Try connecting and powering all up (with good wifi signal on display device, and GPS/GLONASS signal on aircraft). If the RC update is anything like the aircraft then there may be several separate files that need updated to move from V1.6 to V1.8. I'm thinking that the update is not fully completed, or perhaps it needs verification from server ?
Using DJI Go 4 you can check for updates in the 'about' section in the 'General Settings' menu. |
