jimhare
Flight distance : 239035 ft
Hi, Yep, I stem from the BetaCam days as well!
No, I don't use the transcoder, I use DaVinci Resolve to process the clips, but you can use FCPx, it will work great. If your computer is fast enough you should be able to work directly with the MP4/MOV files that come off the Inspire, then color correct to taste. From the LOG files you'll need to add contrast and saturation and then any specialty looks you are after using their built-in color correct tools.
If you don't like to mess around from scratch, there are some pretty good LUTS (think of them like presets) that will get your log footage looking pretty good in a variety of different looks. You need to play with them a bit as they sometimes come on too strong, but all in all give a nice starting point for easy grading.
These ones are pretty good and might be worth it if you want a head start -
http://neumannfilms.net/product/dji-inspire-1-luts/
Just be aware that to use them in FCPx you will also need this plug in:
http://www.colorgradingcentral.com/lututility
All up it would cost $75 but might be just what you're looking for.
scooterlam might have further ideas and gets great results.
Jim
