Help with negative altitude with Active Track
747 1 2017-5-1
OhOhDrone
Flight distance : 526076 ft
I ran into an issue with some of the intelligent flight modes, specifically Active Track. You can see from my illustration below where I lauched my drone at point A and started walking down to point B. Active Track stopped working with the error message being "Aircraft is too low". When I walked back up to point A and regained positive altitude Active Track would work again.
This was a real situation and here are the details. I walked up a sand dune and it was about 20m high at point A and lauched my drone. So it took point A as the base altitude. I wanted to do a side profile Active Track as I walked down the sand dune to point B where my Jeep was. Another scenario for this will be downhill biking with a side profile active track.
Is there a way you get around this?
2017-5-1
Rabe
Flight distance : 967907 ft
I think minimum altitude for active track is a safty feature. The only workaround ist to start the track at the lowest point.
2017-5-2
