Mavic Pro firmware upgrade failed again and again..
107561 1101 2017-5-3
Vinviral
Flight distance : 12556 ft
I am trying to update from 400(factory default) to 700. @Natalia - Could you please help? I bought this drone 4 hr before travel to Hawaii for anniversary trip, Now i have been trying to fly this thing but it requires firmware update. I have tried Go 4 app and Assistant 2 software.  I have also tried to upgrade RC and Aircraft separately. The RC is on latest firmware and aircraft is on .400.
Please add my email to list to downgrade to .350. I have PM'd you email. Else it's viral.eng@gmail.com
2017-6-2
sma2cci
Hey All, I got the downgrade to .0350, and then upgraded to .0600 then .0700 (with camera recording) - now everything works great!  I had PM'ed @Natalia, went on support online chat, and emailed support to ask for the downgrade to be made available. Not sure which was the one that came through, but just thought I'd share that it might be worth contacting DJI through multiple avenues.
2017-6-3
sma2cci Posted at 2017-6-3 09:59
It's good to know that your issue has been solved, enjoy it and hope you have a good time on flying.
2017-6-4
ThomasDT94
Norway
DJI Mindy Posted at 2017-6-4 02:38
Hello!
I also have problems with updating my Mavic. Bought it for 2 days ago, and untill now, all i have done is trying to update it, with failure every time...
I see @the forum that downgrading to .350 , start recording and then try the .700update will do the trick, could you make my account get .350 avalible?
Do i need to use the Assist 2, or can i use the app on my iphone?
2017-6-4
DJI Natalia
Flight distance : 318 ft
Vinviral Posted at 2017-6-2 21:54
OK, will help you handle it soon, hope you could get it fixed.
2017-6-4
DJI Natalia
ThomasDT94 Posted at 2017-6-4 03:06
Hello!
Could you please PM me your DJI account? I would love to help you on this case.
2017-6-4
DJI Natalia
Mackan85 Posted at 2017-5-31 03:45
I got the same issue as well and you got a PM from me with my account information @Natalia.
Thanks in advance!
May I know you managed to upgrade it finally or not?
2017-6-4
Vinviral
@Natalia, I was able to update from .400 to .550. But now I can't update to .600 or .700.
Ppleae help. Online customer service asked me to send drone for diagnostic which dormant make sense to me..
2017-6-4
Vinviral
DJI Natalia Posted at 2017-6-4 18:20
Thanks a lot. I have pm'd you my email.
2017-6-4
DJI Natalia
Vinviral Posted at 2017-6-4 18:38
I am so sorry for the inconvenience caused.
I just received your message, will help you handle it soon.
Please do it step by step as instructions below, hope it works.
1. download the firmware to V01.03.0350.
2. Once it's done, please press the "Record" button on RC and make sure it's recording, then start to upgrade firmware to V01.03.0600, it will be working.
2017-6-5
Hello!
Please PM me your DJI account.
2017-6-5
Vinviral
DJI Natalia Posted at 2017-6-5 00:50
Di i do this upgrade from .350 to .600 or .700 via DJI Go app? Since we need to press Record button not sure if we can use Assistant 2 software, Any suggestions guys?
@Natalia. Thanks I was able to downgrade to .350 successfully.
2017-6-5
Vinviral
Did you use DJI Go app or Assitant 2 software?
2017-6-5
VideoLab
I'm having the same issues.. But I can't go back all the way to firmware V01.03.0350 according to the DJI Assistent. I can only go to V01.03.0550. But i cannot go to V01.03.0600 or V01.03.0700.
Any ideas what could fix it?
2017-6-5
DJI Natalia
Vinviral Posted at 2017-6-5 09:03
Just connect your drone to a PC with assistant 2 installed and upgrade it.
You can link the drone to remote and run APP to make sure it's recording.
2017-6-6
DJI Natalia
VideoLab Posted at 2017-6-5 12:25
What's your DJI account? I would love to help you reconfigure it so you can upgrade it successfully.
2017-6-6
VideoLab
DJI Natalia Posted at 2017-6-6 04:58
What do you mean with DJI account? I thought this was my DJI account haha. Videolab. or is it the email?
2017-6-6
Mackan85
Sweden
DJI Natalia Posted at 2017-6-4 18:24
Hi Natalia,
I'm afraid I still have the same issue. I have not been able to upgrade yet. Any help would be appreciated!
2017-6-6
DJI Natalia
Mackan85 Posted at 2017-6-6 23:22
Hi Natalia,
May I know which step it stops going?
You could downgrade it to 0350 successfully?
Please describe it in detail so I can help, thanks.
2017-6-7
DJI Natalia
VideoLab Posted at 2017-6-6 06:35
The e-mail address when you login the APP or Assistant 2. Sorry I should have made it more clear.
2017-6-7
defiantx
Philippines
Hi DJI Natalia,
Thank you for your assistance. I am now on .0700 version. Cheers!
What I did:
1. Turn on RC (without using the phone/DJI Go App)
2. Plug the Mavic Pro to PC and turn Mavic Pro ON (Make sure the RC and Mavic Pro are connected)
3. Open DJI Assistant 2. Click "Mavic Pro". Firmware versions will be loaded and you should see V01.03.0350.
4. Downgrade the firmware to V01.03.0350.
5. Once it's done, press the "Record" button on RC and make sure it's recording (REC should be flashing on the lower right part of the screen controller), then start to upgrade firmware to V01.03.0600. Once done, upgrade firmware to V01.03.0700
Hope this helps.
2017-6-7
tsp
Hi DJI Natalia,
I sent you a PM as I too am experiencing the same issue that I cannot upgrade past 01.03.0550 on a new Mavic Pro.  The controller will update fine, but the drone will not.  Please let me know if you need more information.
Thanks.
2017-6-7
Ferks
Just bought my Mavic last week and haven't even flown it yet, been trying to update the firmware to 01.03.0700 but it continually fails.
I'm ready to return this thing, very disgusted that a $1000.00 plus drone will not take firmware updates
Help me please before I decide to return it....
2017-6-7
Ferks Posted at 2017-6-7 19:51
We apologize for the inconvenience. Have you tried to update with DJI Assistant 2? If it still failed, may I have the error message?
2017-6-7
tsp Posted at 2017-6-7 08:55
Hi DJI Natalia,
Have you tried with DJI Assistant 2? Please PM me your DJI account. Thank you.
2017-6-7
tsp
Hi DJI Mindy,
I just sent you a private message.  I have tried the latest version of the DJI Assistant App, not sure if that is version 2 or not.  Can you provide a link?
Thanks
2017-6-8
tsp Posted at 2017-6-8 11:32
Hi DJI Mindy,
Have replied in PM, please download DJI Assistant 2 in this link to your PC: http://www.dji.com/mavic/info#downloads
Please refer to tutorial video to update the firmware: https://www.djivideos.com/video_ ... p;poster=null@!1200
2017-6-9
fans1fb9bd65
Flight distance : 17477 ft
Hello,
I just received my brand new DJI MAVIC PRO, and DJI GO4 said to me that i should make updates so i answer yes. And it was the beggining of the problems.  :-(((( It now cannot fly, and i haven't flew with it .
The updates did wrong, again again and again, at 78% the update goes wrong. The update makes my battery wrong. http://hpics.li/120e1d5
Now my mavic is totally bricked, i had some errors messages telling me that the firmware is inconsistant, and it can't install the new on the mavic (my 4G on cellphone is OK).
So i downloaded Dji ASSISTANT 2 on my computer with windows 7, and tried differents firwmares and again and again it didn't work. It fails after a certain % (60% or 78% or 68%).
http://hpics.li/8d5a002
And a screenshot from DJI Go4 : http://hpics.li/9558fce
Please help me, it's a very expensive drone and i'm so disgusted of can't make it fly or work.
2017-6-9
Ferks
Thanks DJI Mindy, I was able to downgrade to .0350, then upgraded to the newest .0800 successfully, thanks !
2017-6-9
tripple
Flight distance : 318038 ft
Switzerland
Ferks Posted at 2017-6-9 10:40
Dear DJI Support,
I can't do the FW Upgrade, too. I am with .550. Please make me able to receive the .0350 to downgrade.
My DJI Email is marcusspahn@icloud.com
Thanks
2017-6-9
fans1fb9bd65
Hello,
After a lot of tries and hours i succed to flash to 0.550 with DJI ASSISTANT 2 on USB 3. But it still goes wrong when i want to go to the latest, and my battery didn't recovering cause maybe i must succed to flash to 0.800 for succeed... Here is my DJI EMAIL : paiement.compte.perso@gmail.com
Thanks
2017-6-9
tripple Posted at 2017-6-9 15:11
Dear DJI Support,
My DJI Email is
Got it, I have feedback your issue to our engineer and I will message you once it's done. Appreciate your patience.
2017-6-9
fans1fb9bd65 Posted at 2017-6-9 16:33
Hello,
Sorry for the inconvenience. I have feedback your issue to our engineer and I will message you once it's done. Appreciate your patience.
2017-6-9
fans1fb9bd65 Posted at 2017-6-9 07:21
Hello,
I'm so sorry about the inconvenience caused. What's the error message in DJI Assistant 2 when it got stuck at 60%?
2017-6-9
fans1fb9bd65
Hello, my mavic is now flying well with 0.550, i had a message error but i don't remember it. I don't want to take the risk of brick my mavic again by a new try to upgrade, but i can do it if it's important. There is still my battery blocked in firmware updating.
Thanks
2017-6-10
stfng
Just sent a personal message with my email for the update issue as well. Let me know when I have the .350 version please. Thanks
2017-6-11
tripple
Switzerland
DJI Mindy Posted at 2017-6-9 22:45
Please hurry - I want to use the full spectrum of the Mavic Features.
2017-6-11
fansb68f75c2
Singapore
Hi DJI Natalia. Noticed you solves many update issues, hope you cn help with mine. I recently tried updating the mavic with dji assistant 2 to 0800 a few times. It didn't work. Intook a chance to update the mavic and the RC to .0550 and it worked! Subsequently, I thought ibwoul try and update the RC and mavic separately. I managed to get the RC to 0800, but the mavic can't be updated. Tried 0700 as well but it didn't work.. what should I do from here? Thank you!
2017-6-11
fansb68f75c2 Posted at 2017-6-11 20:06
Would you please PM me your DJI account? We will help you with that.
2017-6-12
tripple Posted at 2017-6-11 05:32
It's done, please refer to the steps below to upgrade it via the DJI Assistant 2 again.
1. Log into your DJI account.
2.Upgrade the firmware V01.03.0350.
3. Once it's done, please press the"Record" button on RC and make sure it's recording, then start to
upgrade firmware to V01.03.0800, it will be working.
2017-6-12
