Mavic Engine Shutoff After Landing
1053 5 2017-5-4
KKIB
Flight distance : 103022 ft
Hi All,
After takeoff, I was receiving a "strong interference" and "high wind" warnings so I started to land. Mavic landed, I then CSC sticks towards outer corners to shutoff engines, but the Mavic started to lift on the front side. After the third CSC action, Mavic shutoff engines.
Has anyone encountered this issue before?
2017-5-4
lildevilx
Flight distance : 264101 ft
if you're on the ground already, just push the left stick down till the motor shuts off. no need to use the CSC
2017-5-4
KKIB
lildevilx Posted at 2017-5-4 12:45
Got it. Thank you.
2017-5-4
hallmark007
Flight distance : 9827923 ft
Left stick down 3 seconds, the danger with doing what your doing is if the aircraft is not properly on the ground it may just cut out and flip. 3 seconds down will let the IMU know it can't go any lower and power will shut down.
2017-5-4
KKIB
hallmark007 Posted at 2017-5-4 12:57
Thanks for that. I was just going off the owners manual - left stick down, got it!
2017-5-4
K4Unl
Flight distance : 122175 ft
KKIB Posted at 2017-5-4 13:10
To be honest.. this is mentioned in the owners manual...
2017-5-4
