Mcflying
Flight distance : 243753 ft
On which version of OS X are you on? what are the specs? do you have any gate keepers running or some other tools which could screw things up?
I am on 10.11.6 and i have no problems Assistant on my Mac?
So far here are some of the bugs or user experience problems I have encountered:
- The installer launches installation of the HorNDIS driver. HorNDIS stands for "horrendous" which is not very comforting. I have actually used HorNDIS before and I know what it is (ethernet emulation over USB). But less tech oriented users might be confused by this. Furthermore, the installer froze during the HorNDIS installation and gave no confirmation upon completion, which is very unusual. Yes this driver is being installed,...not very user friendly, but it works flawless.
- The app is simply called "assistant.app" so it is not very intuitive to find in the Applications folder. Nothing shows up if you search for "DJI" with Spotlight. Far point, another name for the app would be smarter
- Sometimes the app won't launch at all and won't throw any error message. Never had this problem.
- Once lauched, the app does not put an icon in the dock, or use the taskbar, or show up in the app selector (Cmd + Tab) . You can only close it with the window buttons. If you put other apps in front of the DJI window, you have to hide them all to find it again. This does not comply with MacOS design guidelines and is confusing. When launched it does show an icon in the dock, (cmd-tab) also works and the hidding in front etc is not what i am seeing?
- The app won't work if you don't log in. I don't see why since most of the features don't require account access. Far point, you have to log in, i guess it has to do with downloading the firmware. But it's not an hassle cause you login credentials are saved.
- The app occasionnaly will forget login credentials. Never happend to me, but when using the software i do need to give " admin" access to the app.
- The log in window occasionnaly will claim the user/password combination is incorrect, when it IS correct. Never happend to me.
- Clicking the "forgot password" link will take you to a password reset page. You cannot leave the page, there is no back button, you have to quit the app to log in again. Never tested cannot say
- The app occasionnaly uses 100% of a CPU core even when not in use. Not on my macbook pro?
- Sometimes the app won't detect the Mavic or RC. Unplugging+plugging the USB port works. Maybe a corrupt usb port or usb cable, cause again never happend on my macbook pro.
- The main window occasionnaly disappears. It happened to me during the Mavic firmware upgrade over USB. I had no way to know if it was done upgrading. I had to check wether the app was still running by using the ps command in terminal. It did complete the upgrade successfully. Very strange, but this never happend to me on my macbook pro
- The front sensor calibration tool got stuck at step 3 of the tutorial the first 3 times I tried. It magically worked the 4th time. Never tested cannot say
I really think it is not a software problem but a hardware problem or maybe some software which interfere.
