Geebax
citronade Posted at 2017-5-5 17:13
The DJI Phantom 4 Pro has exactly that, a downward facing infrared sensor that can be used in Terrain Follow mode. Unfortunately it only will follow an upward slope and not a downward one. I'm curious if there is a way to implement it so it can follow upward and downward slope.
And Terrain Hugging is now an option on Arducopter 3.4, so it isn't out of the ordinary, especially if a drone has a built in altitude sensor.
The sensor you refer to is the combined ultrasonic and visual sensor, as fitted to all Phantom aircraft from the P3A and P3P onwards. It has serious operational limitations, a quite short range (unusable above 3 Metres) and is not reliable enough for the task you want to use it for. If it was accurate, DJI would have made use of it already as a feature. |
