Aardvark
![](https://forum44.djicdn.com/data/attachment/common/9b/common_15_usergroup_icon.png) First Officer
Flight distance : 384432 ft
quikdom Posted at 2017-5-9 00:01
I always keep firmware and apps updated. The interference has been happening since late last year just tried to ignore it but as the weather is getting better I want to try and get out there.
One suggestion might be to roll back the firmware on the RC from V1.8 to V1.6, this may help clear up things a bit. V1.8 seems to have caused issues for a number of Android devices, whether through program error or hardware limitations I do not know.
Try the following and see if it's of any help, if not you can always reload V1.8.
Connect display device (with good wifi connection) to RC and power both up (aircraft off).
Run DJI Go, on initial screen (where it displays aircraft type etc) at top right hand corner you will see a 'graduation hat' icon (or perhaps three lines if DJI Go 4). Hold your finger on that for about 5 seconds and release. You should now see a black screen appear with an option to roll back RC firmware (you may have to sellect V1.6 in the roll down menu). Make sure RC is well charged, takes about 5 minutes or so. Power down when complete. Restart all and check all working, you may need to relink RC to aircraft. |
