Bill in Ohio
Bill in Ohio Posted at 2017-5-15 06:09
Thanks, I will try that. I have tried my Samsung Tab A (it won't connect the USB port, it flashes up to ask make this default, but goes away to quick to touch), my Samsung S 7.9 inch has extreme video lag , but my wife's Samsung Galaxy 9.7" S2 works awesome. My phone Samsung S7 worked well at under DJIGO 4 v...4 point, but then became unstable for .5, .55, then OK for .6 for awhile, then unstable with .7. Once I get it repaired (dropped it onto concrete floor with the case off) I will try again and try using only the 1920x1080 screen mode, also the lowest level "Read" versus the other two fancier screen modes, the bottom USB instead of the side, etc. To see if anything helps. People with S7 edge say they are doing fine, I don't think there is much difference between the S7 v S7 edge.
I will try as soon as I get it fixed as the glass is shattered but the phone works. Experimac is going to replace the top and bottom, costs $250.
I tried using the middle USB cable as well as the side USB cable with the following adjustments to my Phone and everything went well.
Samsung S7 settings: Blue light filter off, Screen Mode Basic, Screen Resolution 1920x1080, Wifi Off, and Blu tooth Off. |
