No difference in Mavic Prodrone reactivity when exiting beginner ...
465 2 2017-5-9
Hans10
Hi,
I have a DJI Mavic Pro and when I exit the beginner mode the drone does not respond with a different reactivity.
When I switch to sport modus (right side control button) it does, but is then a little too responsive so I would like to use the regular modus.
(button multiple flight modes is ON, otherwise the sport-mode is disabled).
I re-installed the latest firmware but that did resulted in a difference, 'm still only able to switch between beginnner and sport modus, no regular mode.....
Any tips or experiences would be appreciated !
2017-5-9
Ex Machina
Flight distance : 1806362 ft
Beginner mode simply limits your flight radius and height to 30m.
You can adjust the responsiveness of the controllers in the DJI Go 4 App prefs.
2017-5-10
JaushG
Flight distance : 412106 ft
Beginner mode only keeps you from flying to far away until you are ready. To change the sensitivity and such, go to your menu then main controller settings then advanced settings then exp and sensitivity. There are videos on this. I wouldn't suggest changing any Gain settings until you know what you are doing.
2017-5-10
