Strange noise from the center of the drone when turning upside down
930 9 2017-5-9
kovbenc
Flight distance : 128560 ft
Hungary
I have a week old P3 Standard. Today I've noticed a clicking sound coming from the top-center of the drone when I turned it upside down (and back). It sounds like a small plastic piece is falling around in a small place... but my drone is unharmed, had no accidents. Could it be maybe one of the sensors? Do you guys also hear a noise when turning the drone upside down and back? I'm a bit concerned... but I hope it's just a false alarm. :-)
2017-5-9
Eric13
Flight distance : 14950167 ft
On my P3S there is no such noise when I turn it upside down...
2017-5-9
Dave Kent
Perhaps it's a part of the body were a screw goes into that broke off due to heat or stress/age.
2017-5-9
kovbenc
Hungary
Thanks... :-) The drone is almost brand new, so aging is not a problem. I suppose I can't open up the body because it would void my warranty... So I guess I just have to live with it. Hopefully it won't get worse.
2017-5-9
WD9EON
Flight distance : 686886 ft
kovbenc Posted at 2017-5-9 09:30
leave the battery out and turn it around, maybe what ever it is will fall out.  At least the noise may stop.
2017-5-9
DJI-Ken
Flight distance : 1515312 ft
It may just be a piece of plastic flashing.
Your more than welcome to send it in for evaluation if you like.
Does it sound light and plastic, or heavy and metal (like a screw) when you shake it.
And yes, remove the battery and it may come out.
2017-5-9
kovbenc
Hungary
Dear Ken,
Thanks for the answer! I listened to it again... and it really sounds like a switch, and not sime small plastic waste. The sound is kinda soft... I wish I could record it and play it for you. :-) I live in Hungary, Budapest. To where could I send it in if I wanted to?
2017-5-9
Cabansail
Flight distance : 136686 ft
Where did you purchase it?
2017-5-9
kovbenc
Hungary
fpvshop.hu, Hungary
2017-5-9
kovbenc
Hungary
Yeeeeeeeah, I've found the source of the noise!!!!! It's the connection reset switch. :-) If I take out the battery and put a screwdriver inside the reset hole, then I can clearly see that the screwdriver pushes a small transparent cap, which makes this noise. I'm so relieved now.... :-)
Video URL: click here to play video with sound
2017-5-10
