Firmware - Intelligent Battery Update
2318 10 2015-3-7
Arvada
Flight distance : 398822 ft
All,
The latest firmware update instructions indicates that the batterie's firmware will ALSO be updated while the aircraft is updating its firmware.   Doe this mean I should power off the aircraft after the update then recycle the power with my other batteries as well?
Is the battery update part of the aircraft circuitry or is it part of the physical battery?
Comments?
Arvada
2015-3-7
snathla
Flight distance : 5045295 ft
Yes, that is what I did as well, this way the update can happen on each battery
2015-3-7
Arvada
snathla@gmail.c Posted at 2015-3-8 00:28
Thanks.  It was implied.  Since they specifically instructed about updating multiple remote controllers, I wasn't sure if there were specific instructions for multiple batteries.
Were there any log files to delete after each update of the aircraft?
2015-3-7
lasuncion
Guam
I'm also curious on how to update the Intelligent battery especially if you have multiple batteries. Do you insert them on the Phantom and do the firmware update again?
2015-6-10
w1der
Sweden
After the first update is ready ...
Power the inspire OFF ... replace the battery ... Turn the inspire ON (the RC should NOT be turned on as this will cancel the update sequence of the next battery) ... wait a few seconds.
As the update is in progress you will here the same sound from the inspire as during the first update but the LEDs on the battery will also flash indicating that they are being updated.
I did not need to remove any text files between the first and second update for the update sequence to initiate.
Note: just leaving the firmware file on the card isn´t going to generate the firmware update on your other batteries ... it needs to be done as explained above. This update is only a few minutes so I suggest you update all of your batteries right away and be done with it ...
2015-6-11
chris
Flight distance : 242247 ft
When I did the battery update on 5 batteries, I checked the 1st update in the text file and it showed success. So I continued to update the reaming 4, when I checked the file it showed Upgrading on the 4 but did not show success. Thinking I might have shut down the battery before it was completed I started the upgrade posses a 2nd time. This is what the text file showed.
========== 2014.01.01 00:00:11 unsynchronized ======
Packet: WM610_FW_V01.02.01.06.bin
Upgrading ...
Result: Success.
Upgrading ...
Upgrading ...
Upgrading ...
Upgrading ...
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.06.07 10:30:11 =====================
Result: Abort.
========== 2015.06.07 10:33:09 =====================
Result: Abort.
Result: Abort.
Just worried that the update on the last 4 did not complete. Any ideas?
2015-6-11
w1der
Sweden
chris@corp-medi Posted at 2015-6-12 00:13
When I did the battery update on 5 batteries, I checked the 1st update in the text file and it showe ...
I am not sure if the battery generates a text file or not ...
The manual only mentions text file from the Inspire and from the remote.
Can some one confirm this ?
2015-6-11
chris
w1der Posted at 2015-6-12 03:14
The manual only mentions text file  ...
The text file above was from the batt update only.
2015-6-11
w1der
Sweden
chris@corp-medi Posted at 2015-6-12 05:44
Yes ...
But it is reffering to "the air craft" ... not the battery.
And this is confusing (at least to me).
2015-6-11
mtnmaddman
w1der Posted at 2015-6-12 15:30
Yes ...
And this is confusing (at le ...
Notice the bin file no. is all the same it appears as though it loaded it, I dont quite understand either, give us a comment tahoe ed.
2015-7-7
Arvada
Chris,  can you check something for me?  As you fly a lot this may not be something you might notice but after the "multiple" battery updates, I checked a few of my batteries 12-14 days after they were to trickle discharge.  None of them did.  Plugging them into I1 show they are to DC after 10 days....but they didn't.  None of them.  But the firmware update on each battery was successful.
Thoughts?
2015-7-13
