BearDrone
Flight distance : 2887251 ft
DJI-Jamie Posted at 2017-5-11 13:39
Yes, the IMU calibration would be done via the Go app. If your unit needed a firmware update, you would receive a notification in the Go app along with the option to update through the app as well. Should you need to perform an update and you experience any difficulties doing so through the app, the Assistant 2 software would be the only other way to do so in order to rule out a hardware issue.
Please give the IMU calibration and gimbal calibration, though, when you have the chance.
Okay, I checked for updates on the firmware via the app, and evidently I'm running the latest version since it did not prompt me to update anything. I did an IMU calibration and another gimbal auto calibrate. The weather has been pretty awful here, so I probably won't be able to fly anytime soon. Maybe early next week.
I did discover a setting in the gimbal section called 'gimbal roll'. I am assuming this is a way to fix this tilt if it persist?
Thanks very much for the help. |
