realdeal
Flight distance : 37680 ft
hallmark007 Posted at 2017-5-16 14:46
As I explained to you earlier your Aircraft didn't fly away it went into Atti mode and if you read your logs it responded to your stick movements, you chose to raise your aircraft which was the right move, but while you were doing this your aircraft was drifting in Atti mode if you had used other stick movements you could have controlled your aircraft but Atti mode is not easy, and you were lucky you regained gps and stability.
My conclusion is the environment you were flying in was effecting your aircraft where the interference was coming from I do not know, but it was there.
nope, after losing video i walked over to check on the aircraft assuming it was hovering according to the flight history video, i had no control at all and as some pointed out the flight records show this with errors.
The records clearly show it flew away, let me know how this happened as my remote had lost connection, no video feed, no more info on the FIND MY DRONE map other then that last point i had in site.
the DJI engineer explained that the last drone scenario was the remote, but had no idea why the RTH function did not work.
This drone shows the same type of scenario but more flight info, including the distance from home, you would think it would return by itself if the battery went low no? i tried hitting the RTH over an over and over for 5 mins, nada |
