Does concrete interfer with the mavic?
1553 10 2017-5-15
AidoH
Flight distance : 369199 ft
Hi All
I have just upgraded to the Mavic pro from my Phantom 3 Standard.  I was not able to take off from concrete with the P3S due to the steel in it, would interfer witht he compass.
Can the Mavic take off from concrete or does the compass still get interference?
thanks in advance
Adrian
2017-5-15
DroneFlying
Flight distance : 10774613 ft
The compass can definitely be affected by interference from the steel rebar embedded within concrete, causing the Mavic to become nearly uncontrollable. In most cases it'll eventually stabilize, but not -- as happened to one person who posted here recently -- if you crash before that happens. If anything I'd guess that the Mavic will be even more susceptible to this than a Phantom since its body is even closer to the source of the interference when it's on the ground.
2017-5-16
hallmark007
Flight distance : 9827923 ft
When taking off from concrete or anywhere else, just take time to check you compass arrow is pointing on the right heading and you should be ok.
2017-5-16
fansfddc5315
Flight distance : 74482 ft
Dominican Republic
hallmark007 Posted at 2017-5-16 02:30
Hi,
Do you mean an external dedicate compass ?
Thanks,
2017-5-16
hallmark007
fansfddc5315 Posted at 2017-5-16 04:18
Hi,
No in the bottom left hand corner of your flight screen you will see a small red triangle on a map, when you put your drone on the ground getting ready to fly check to see if this arrow is pointing in the direction of where your drone is facing, this is the heading for the compass.
Let's say your drone was facing straight forward and when you look at your screen your red triangle is facing a different direction, this can mean there is some interference in your compass and you might need to move and take off from a different spot.
Most of the time you will get a warning but not always, no need to get worked up about all this no need to do calibration just move to a place where drone and compass have bot the same heading.
2017-5-16
hallmark007
Hi,
Here's a video which will show you what happens when you have a problem with compass.
2017-5-16
fansfddc5315
Dominican Republic
hallmark007 Posted at 2017-5-16 04:31
Ok noted. Thank you for the tip, very helpful.
2017-5-16
AidoH
Thanks for the rplies, as I thought best to be safe than sorry and keep off the concrete.
2017-5-16
Parkker
Flight distance : 8891 ft
Only concrete with steel rebar reinforcement will potentially cause problems. Not all concrete has this reinforcement. Just try and see checking red arrow compass indicator as others have mentioned prior to taking flight.
2017-5-16
NoSale
Flight distance : 460958 ft
I generally look at the compass sensor reading before take off to insure there is nothing affecting the compass.  I have witnessed sitting on concrete the compass sensor gives error readings.  Then I can move it to a grassy area, and the compass errors go completely away.  This is what I look for before starting my flight.........
2017-5-16
TrollsSlayer
Banned
2017-5-16
