bugman
P2V+ 3.0, purchased in 12/14.
Have flown probably 30+ flights with no MAJOR flyaway-type issues (although a couple slight scares - but that's for another thread).
Have noticed several times that the battery indicator (the number & % sign for the battery in the bird) will sometimes turn RED on me.
Not just when bettery level gets low, but when level is still quite high. Have seen it happen at 85% battery available - I'll look down & indicator will be red rather than blue. (Have also seen at 60-ish%, 40-ish%, etc). Battery warning is set to 20%.
It turns gray when wifi signal is lost, and a couple of times I thought maybe that wifi signal being lost) was related to it going red also, but I've since seen it happen while wifi signal was def still connected.
So far, it has always been just momentary - red for 5-10 seconds, then back to blue, and flights have been completed without actual incident.
Any ideas?
