Battery duration test: will it last longer than 27 minutes?
1619 10 2017-5-24
Peut
Flight distance : 1761181 ft
Recently I did some tests with the DJI Mavic Pro in regard to travelling distance in various modes. Today I tested the battery life, will it last longer than 27 minutes, which is the given flight time on a single charge?
For this test I entered fixed wings mode because of it constant speed, the Mavic flew around 15 - 16 km/h, at this speed it came suprisingly far Also, it was not to windy that day and I switched off as many sensors I could.
2017-5-24
thehippoz
Flight distance : 23 ft
When battery was new, think did over 23 minutes once according to airdata. That was running poi over a large area around the same speed.
2017-5-24
Peut
thehippoz Posted at 2017-5-24 09:51
Did you have a lot of wind that day? Did you drain the battery under 10% or landed before?
2017-5-27
boostedford
Flight distance : 144478 ft
i dont think mine has ever flown more than 15-20 min
2017-5-28
thehippoz
Peut Posted at 2017-5-27 23:31
Landed I believe with around 10%. I run older firmware from december. Have to check old airdata records.
** Looks like the ones from december already gone. Guess too many records for free, but here's one from feb was 21 minutes in the air. Notice the battery temp. Only 111 degrees and had around 15% left. That's pretty cool for the mavic battery. Ambient was even cooler in december. Flew over the weekend and think got around the same. In sport mode full out seen it as low at 11 minutes in air. You want to keep the battery under 140 degrees.
https://app.airdata.com/main?fli ... bddc19f6d7eb99ad943
2017-5-29
Panaceabeachbum
Flight distance : 871430 ft
I have a 31 and 33 min flight so far. Mostly hovering at 120 feet over poi
2017-5-29
thehippoz
Panaceabeachbum Posted at 2017-5-29 17:22
Wow that's awesome
2017-5-29
Bent Kangaroo
Flight distance : 362510 ft
boostedford Posted at 2017-5-28 19:12
I think i cracked the 20 minute mark twice with 21 and 22 minutes.
Other than that all flights only last to around 19 minutes to the 30% marker.
2017-5-29
DTK
Flight distance : 1943159 ft
What I notice from Inspire 1 is that the battery capacity deteriorate steadily after each charge. For sure, this will affect your flight time every time you fly.
2017-5-29
Panaceabeachbum
This pretty standard with all rec batteries, best capacity around number 4 or 5 then a gradual decline.
2017-5-30
Peut
Nice job!
2017-6-3
