Nigel_
Flight distance : 388642 ft
"most likely you will be OK."
That is true, but what happens if the less likely actually happens?
A Phantom battery is very different to a phone battery, if the phone bursts into flames then it will probably run out of fuel and extinguish itself before igniting anything else, although you should still be careful of where you charge and ensure that there are no flammable materials near. However the Phantom battery has maybe 10 times the power stored in it, if it ignites then there is a far higher chance of it burning the house down.
So make sure that you are awake and either in the same room or within hearing range of the smoke alarm that is watching it, and have a suitable fire extinguisher easily accessible.
It is very rare for Phantom batteries to have problems, but drone batteries have been known to burn down houses.
When I charge mine, it is sitting on an aluminium table with nothing flammable nearby. |
