kasei
Flight distance : 118399 ft
i wouldnt use autopilot modes over water at all
the manual says the vision position systen may not work correct over water, reflcective surfaces etc.
3D Sensing and Vision System performance are affected by the type of surface being flown over.
The aircraft will switch from P Mode to ATTI Mode automatically if neither GPS or Vision System are available.
Please be vigilant when operating Spark in the following situations:
• Flying at high speeds below 0.5 meters.
• Flying over monochrome surfaces (e.g., solid black, solid white, solid red, or solid green).
• Flying over highly reflective surfaces.
• Flying over water or transparent surfaces.
• Flying over moving surfaces or objects.
• Flying in an area where the lighting changes frequently or drastically.
• Flying over extremely dark (lux < 10) or bright (lux > 100,000) surfaces.
• Flying over surfaces without clear patterns or texture.
• Flying over surfaces with identical repeating patterns or textures (e.g., tiling).
• Flying over small and fine objects (e.g. tree branches and power lines).
• Flying at speeds of over 6.7 mph (10.8 kph) at 2 meters above the ground. |
