FPV with GoPro Hero 4 & Phantom 2
10591 10 2014-10-11
scott7161
I'm using a Black Pearl RC801 and Flysight 5.8Ghz 400mw transmitter.  It seems to work okay with the GoPro Hero 4 however, I notice the range of the FPV signal seems to be less.  I used to be able to get out to 2kM without any trouble and even to 2.9kM under best case conditions and now with the Hero 4 on channel 8 (whichs seems to give me the best range) - I'm limited to about 800M or so and the picture starts getting snowy around 300M.
Anybody else using the Hero 4 with an analog (non-lightbridge) FPV setup and getting good results?  It might be that my transmitter is failing.  I haven't had time to switch back and forth from the Hero 3+ to the Hero 4 and see if the issue is still present.
Thanks,
Scott
2014-10-11
Cloud9
Switching the camera shouldn't make a difference. The GoPro just feeds the video to the transmitter, so the issue would be the transmitter or receiver.
Anything change on your setup other than the camera?
2014-10-12
scott7161
Cloud9 Posted at 2014-10-12 16:59
Switching the camera shouldn't make a difference. The GoPro just feeds the video to the transmitter, ...
Nope, just changed the camera.  I'm ordering a new transmitter to see if that fixes the problem.  I've also tried different antennas without any luck.  Thanks for your reply!
2014-10-12
Jarret
scott7161@gmail Posted at 2014-10-12 23:55
Nope, just changed the camera.  I'm ordering a new transmitter to see if that fixes the problem.   ...
The hero 4 is not compatible with FPV. I bought one and had to take it back. Sucks that DJI isn't keeping up with tech.
2014-10-22
Serafin
Jarret Posted at 2014-10-23 15:08
The hero 4 is not compatible with FPV. I bought one and had to take it back. Sucks that DJI isn't  ...
Really? Several users report being able to use them. What do you mean not compatible with FPV? It may be your specific setup.
2014-11-7
erikgraham
Flight distance : 55128 ft
Shouldn't you turn off the wifi on the GoPro 4?
You don't need it and it will just interfere with the phantom wifi transmitter....
2014-11-7
Cloud9
It works..been using it for about a week with no problems.
And yeah, wifi on ANY GoPro during flight is a big no. Unless you're trying to lose your Phantom
2014-11-7
scott7161
I found out my problem was twofold -  that the gimbal was vibrating due to being unbalanced by the new GoPro and that I needed to change channel frequencies.  Once I got that worked out - things are better...  Thanks everyone!
2014-11-12
skrantz
Sweden
scott7161@gmail Posted at 2014-11-13 13:40
I found out my problem was twofold -  that the gimbal was vibrating due to being unbalanced by the n ...
Hi,
Iam new to UAV and have just bought a rctimer800 second hand to try this hobby out Before I spend $..
Anyway, I have a GoPro Hero 4 Silver.
Iam realy intrested in what kind of Equipment you buy to get FPV from GoPro4? Links or DIY guides etc...
Thanks in advance.
/Stefan - Sweden
2014-11-23
Droneasaurus
Hi. I am a hobbyist looking to upgrade to a phantom platform. I am really torn between the Vision + or going with the GoPro Hero 4 Black. I live in Canada and want to use for commercial purposes so I would love to have the 4K option, but on the other hand I don't want to spend a fortune on the lightbridge. What can you suggest as some possible set ups that I should consider with a minimal amount of modification. Thanks!
2014-12-16
Cloud9
skrantz Posted at 2014-11-24 06:08
Hi,
Iam new to UAV and have just bought a rctimer800 second hand to try this hobby out Before I s ...
http://forum.dji.com/forum.php?mod=viewthread&tid=943
http://forum.dji.com/forum.php?mod=viewthread&tid=1221
2014-12-17
