Mavic Glare
1783 5 2017-5-30
fans27aa2d51
I purchased and mavic pro in early April and got one with the glare issue.  Ended up returning it and plan to buy another but I cannot determine if the company has fixed this issue.  Does anyone know if this is still a problem in the latest shipments?
2017-5-30
DemolitionMan14
Flight distance : 1963583 ft
I only got glare when i had the clear globe on.  Took it off and no glare.
2017-5-30
fans45e3d08c
I just bought 1 from amazon 2 weeks ago, and with 2 calls to DJI no luck with fixing the same issue you have.
2017-6-29
DroneFlying
Flight distance : 10774613 ft
fans45e3d08c Posted at 2017-6-29 15:31
Specifically what is the "glare issue" that was mentioned in the earlier posts that you're seeing? If you mean glare when facing the sun or that is caused by the gimbal cover (the "bubble") that's normal and there's nothing you can do about it.
If the problem you're concerned about is something different then the best way to demonstrate what you're seeing may be by posting a picture or a video.
2017-6-30
djiuser_gnY8LkA
Just bought a mavic, any footage when the sun is out produces a glare that covers 10-80% of the screen, WITHOUT the gimble cover, WITH a lens hood!
Seems like this is a common issue with mavics.
SMH.
Returning for a refund
2017-10-2
Bekaru Tree
Flight distance : 15513100 ft
South Africa
it is a common issue with filming into (actually at about 45 degrees away from the sun) -
2017-10-2
