Ville Honkonen
Flight distance : 80919 ft
Finland
Ex Machina Posted at 2017-6-2 06:04
It appears there are two issues going on here, the effect of negative sharpening values on footage in lower and high-contrast light, and a plain focus problem that (temporarily?) goes away when you reset the camera stack. Your two videos show the first issue where negative sharpening works fine in good light, not so much in lower and high-contrast light. This is well documented in the forum.
Your subsequent posts detailing the focus changes you detect when resetting the camera has also been reported in the forum, but if it's a software bug then it must affect a minority of Mavics, perhaps only those in a particular production run, because I haven't been able to replicate this on mine and the reports are uncommon but predate this recent Go 4 update. It's very mysterious to me.
Like i say in earlier post: this is 0,0,0 settings and only what i have change is the color profile, focus is manually set. And this error comes only one's.. the first time when you update the dji go software. And why i talk this.. it's because this software error cost me a lot of money because i can't use that material. I have use Dji Go software from Dji Phantom 1.1.1 so i think that i know how this should work...
The left is before and right is after, i only push color profile None, nothing else:
