R/c swapping
877 12 2017-5-31
Axor11
Flight distance : 687028 ft
Hi..is it possible to swap my r/c with my friends r/c..
2017-5-31
Harbourside
Flight distance : 6467 ft
You can swap whatever you like with your friend, no need to ask permission here....lol
The devil is in the details...
2017-5-31
Axor11
Ahaha tks for your permission..
2017-5-31
Axor11
Is it just a case of linking his r/c to aircraft
2017-5-31
Harbourside
As I said, details.....
Assuming you are talking about a Phantom R/C, then we need to know which model you have and which your friend has.
Not all Phantoms use the same transmission system.
So to tell you for sure we need to know the details...
2017-5-31
Axor11
Sorry...both are phantom 3 standard
2017-5-31
Michgolden
Flight distance : 822851 ft
If they are both Standards then no problem. You just have to go through the linking process each time you switch back and forth.
2017-5-31
DJI-Jamie
Flight distance : 112405 ft
I concur with post #7.
2017-5-31
Axor11
Tks for the help..trying to see if it helps with my bad signal
2017-6-1
Axor11
Wishful thinking..didn't change a thing
2017-6-2
Axor11
I hate my phantom
2017-6-2
osava
Turkey
hi. can i use the phantom 2 vision v3 controller with the phantom 3 standard. thats look same.
2017-6-10
WD9EON
Flight distance : 686886 ft
osava Posted at 2017-6-10 14:01
Pretty sure the answer is no.
2017-6-10
