DefconX3
Flight distance : 1250564 ft
hallmark007 Posted at 2017-6-1 09:17
I think Griffith might be right I would check compass IMU can also cause drift but it wouldn't be intermittent you would see it constantly. Unless it's the wind.
You can do IMU test.
Went through the IMU checking process you described, everything seemed flawless. Drone was rock solid, without a sign of issue.
However, I looked through some of my flight data and noticed something off. During a RTH, the path recorded was perfectly straight, even though the drone on video looked like it was drifiting. I found out today that my drone, rather than drifting, is actually flying at an angle. In other words, the angle in which the drone is flying is not in line with where the camera is facing. This gave the illusion that it was drifting off course.
This finding leaves me to suspect that wind is at fault for this behavior. From what I'm assuming, the drone is being forced to yaw. The drone compensates for this by adjusting the motors RPM's which keeps it flying straight, but not inline with where the camera is facing. But if my speculations are true, why doesn't the gimbal react to this and move inline with the drones direction?
Another slight issue that I noticed. When making maneuvers such as turning a full 360 degrees, it almost seems like the camera is temporarily disoriented. The camera began to very slowly pan to the right for about 30 seconds, until finally stopping in the correct direction. |
