Video feed delay by up to 20 plus seconds
534 4 2017-6-2
Elbert H.
Flight distance : 6299455 ft
This problem really seems weird. I'm experiencing delays of up to 20 plus seconds on my video feed from my drone.  And, I know it's not the drone, as I have 2 Phantom 3 Pros, and it's suddenly happening to both of them.
Also of note, all other commands to the craft are basically instantaneous, including the gimbal mout. It's just that when you say.....point the camera straight down.......it takes about 20 seconds for it to display the video feed.
Outside of the delay, the video quality is excellent.
Any idea out there ???
2017-6-2
fansf7de364f
Flight distance : 303917 ft
Austria
Same problem with 2 mavi pro´s ... :-(
2017-6-2
Elbert H.
fansf7de364f Posted at 2017-6-2 08:21
Sorry to hear that. Lucky me, I just tried it again, and lo and behold everything is back to normal.
Only problem is I don't know what caused it ! Interference of some kind that's not presaent now. It's the exact same location the problem was at.
Well, good luck with your Mavic !
2017-6-2
endotherm
Flight distance : 503241 ft
Elbert H. Posted at 2017-6-2 08:40
It's probably the device you were using.  Is it on the recommended device list?  If the CPU is too slow or there are lots of apps running in the background or it gets too hot, you will see funny things like this happen.   If it was working fine before and is again now, you probably rebooted it and stopped all the CPU-hogging programs running in the background.
2017-6-2
AndyP.
Flight distance : 1723520 ft
endotherm Posted at 2017-6-2 11:15
I second this, if the phone is too slow it could cause problems
2017-6-2
