steadystickrick
Den,
I ordered the RE700 which should arrive this week....
....however, I did fix my problem. I downloaded an APP called ScanLife from the Apple store (it's FREE)
After countless hours deleting and re-installing Apps, Firmware, and Bin.files....I couldn't get my DJI Vision App to scan the QR code.
I scanned the QR code that came with my Phantom (on the box) with the ScanLife App....a lot of numbers came up which identify DJI, the Phantom model, the Serial number of the camera, the SSID and the MAC address too....
I powered up my RC unit and then the RE500 wifi extender and waited until the green light on the extender was flashing....then I powered up the Phantom....waited until everything went through the sequence and then I reset the extender by holding the button in until the blinking green light went off....released the reset button and waited until the extender started blinking green again (30 secs or so)
I grabbed my I Phone 4S and located the Phantom and connected to the Wifi Signal with Airplane mode on...opened Vision App and made sure the Phantom wifi signal was indicated and then I went to the Settings menu and hit "Binding"....when the screen came up for MAC address I "tapped" on the area and "manually" entered the last six digits of the camera MAC address in the appropriate area....then hit the blue check mark on the upper right corner...hit it a second time and a little wheel spun for a few seconds and it changed screens...
At this point I powered everything off and powered up the RC unit first and then the extender.....waited until the green light flashed and powered up the Phantom....waited and connected to the phone and opened the Vision APP and hit "CAMERA"....Volia! Ground station and camera was working....all fixed...
Notes: BE PATIENT!! Allow at least 30 secs...or so between each step after the reset....give the camera time to send its signal....and make sure you start by deleting you DJI Vision APP and re-installing it before starting the process....
Hope this helps others too....especially when they cannot use the QR scan feature of the DJI Vision APP....another mistake early on was that my phone did not read the camera on the wifi network area of the phone....and I kept mistakenly adding the last six digits of the WIFI unit in the camera MAC address area rather than the camera's MAC address....once I used ScanLife I realized I had the correct Camera MAC address...
Not sure why DJI couldn't take me through this process.....rather than request that I send in my Quad for service...looking forward to adding the extended range of the RE-700 extender this week.
I'm resolved to the fact that the Re500 with latest upgrades DOES NOT show the battery life percentage on a Phantom 2 Vision....it would be nice that DJI would tell people that....it would eliminate a lot of frustration and confusion. Hopefully, the new RE-700 will show the extender battery % when I install it.
Rick
