ibx
Flight distance : 40938 ft
i only have the phantom 3 standard, sorry.
I would assume its pretty much the same setup, but first make sure your videos are set to record in 4k using the dji go app. use the usb cable supplied with your phantom and connect it directly to the camera on the phantom and pc. make sure the phantom is on when doing this and it should work pretty much like any mass storage device that should get you what your looking for. as for photos, make sure your photos is set to raw or raw/jpg. use the raw file and you can easily edit your photos using applications like photoshop.
i hope this help. |
