N3 blow up
1864 5 2017-6-2
LONGSHOT3506
Flight distance : 18326677 ft
South Korea
Hello my N3 is blow up in flight all motor stop and my drone is crash after i reconnect the battery but N3 is not work i can't see log data
imu-pmu connecting part is melts down
I found the answer.
N3 died in flight
lost control
my drones crashed.
After the crash all ESC beepping it means no signal from N3
I was believing in dji N3 but it is dead in flight I'm in shock
2017-6-2
DJI-Jamie
Flight distance : 112405 ft
When you say it blew up, do you mean it just stopped working, overheated, or literally blow up? Is this after initially setting it up, or after a firmware update or a previous hard landing?
2017-6-2
LONGSHOT3506
South Korea
DJI-Jamie Posted at 2017-6-2 22:59
Hello jamie
I flight go Straight  suddenly all motor stop and crash
after I listen esc beeping (It means no signal from N3 lt stop working)
and N3 did not work again.
setting is good  (I flight 2 times)
firmware is last version (update before 2 flights)
N3 is not a damaged because It is new
2017-6-3
DJI-Jamie
LONGSHOT3506 Posted at 2017-6-3 00:37
Hello jamie
Just to make sure I'm on the same page, all the motors shut off when solely flying straight and nothing else? In regards to the beeping, do all the components (IMU, PMU, GPS etc) show up when connecting the N3 to the Assistant 2 program? Are you able to connect to the Assistant 2 software at all? Any visuals that you could provide to better explain the issue would be appreciated.
2017-6-5
LONGSHOT3506
South Korea
DJI-Jamie Posted at 2017-6-5 11:49
My drone flight as usual suddenly N3 stop working
N3 and Assistant 2 program work very well before flight I check (IMU,PMU,GPS) ALL green
But  It won't turn on after crash
Today I send my N3 go to Hong Kong DJI service center
I will wait for the results of the black box analysis
p.s( I wanted to attach pictures, but I don't know how to do it.)
Thank you for reading
2017-6-7
DJI-Jamie
LONGSHOT3506 Posted at 2017-6-7 05:23
The Hong Kong Service Center will help get this sorted for you, good to hear it's getting addressed. If you want to add photos, you can hit the Advanced tab when replying to a post and you can upload an image that way.
2017-6-7
