eaglecook
Well, you'll have to crank up your ISO and slow down your shutter speed. This will make your images possibly be noisy (due to the high ISO) or suffer from motion blur (due to the slower shutter speed). Shooting at 4K means you will be at 24 or 30 FPS so to get a clean image you will need to have your shutter at 60 minimum, I would even recommend higher, 80 or 100, then adjust your ISO until the image is as good as it can be. This will be a personal choice and will be a compromise between exposure and noise. No matter what you do, I doubt you'll get a "good" image with that little light. You will definitely need to do some heavy editing in post production. Also if you are planning on taking stills from video, be sure to keep the bird and camera as still as you can for the time you see the shot you want. Even a little movement will cause motion blur unless you crank up that shutter speed, and you won't have enough light for that.. .(unless you are in a really bright city).
Overall suggestion: experiment with it using these suggestions as a starting point. shoot a little, change settings, shoot some more, tweak setting etc.
Also, why not just capture an image? Why do a video grab? Why not try both?
Best of luck and would love to see what you come up with. If you post, maybe the group can help based on what you get. |
