fans33885c62
Flight distance : 1006342 ft
Greetings UAV operators,
I've had a long and successful spring so far with about 50 flights logged, really loving the 4, I haven't had many issues (no serious ones anyways) with it.
However, as the temperatures outside start to climb (I'm in Ontario, Canada), I've noticed an increase in video signal connectivity issues.
I've had it happen a few times recently and the only common factor I can think of is direct sun - no clouds, and temperatures above 25 degrees.
Essentially, if it gets too hot outside I have to fly without video on the iPad.
Is there anything that can be done to compensate for the heat? And why don't operators in consistently hot locations have the same problems?!?
Or am I totally off as to why the increase in signal connectivity is happening?
