Quick Shots for the Mavic Pro
1734 13 2017-6-7
user7c4b8b4be6
Hi
Are there thoughs on if the Mavic Pro is going to get the Quick Shots options that the Spark has ? And if so when ?
2017-6-7
raptor30
Flight distance : 947733 ft
Philippines
just now, mavic''s got quick shot modes
2017-9-18
hallmark007
Flight distance : 9827923 ft
It's now available on iOS , quickshot is a bit gimmicky, but good fun, I will try it on Mavic later.
2017-9-18
Dirk52
Flight distance : 232995 ft
hallmark007 Posted at 2017-9-18 07:42
You have to wait for the FW update...
2017-9-18
hallmark007
Dirk52 Posted at 2017-9-18 07:48
Sorry to burst your bubble, but I've just tried dronie and target they are indeed working just fine in fact dronie is very impressive, I do realise you have to wait for new firmware but only to sort out recording, so yes it's available to try out but it won't record it will preform the flying exercise.
2017-9-18
hallmark007
You can go out and try it, it actually works a lot better than it did on spark when first released.
2017-9-18
AkyHun
Flight distance : 886926 ft
Hungary
hallmark007 Posted at 2017-9-18 08:50
How Can you access the new quickshot mode? I did update the firmware and turn on the AC (did not fly) but couldn't find the new modes in the intelligent flight modes menu.
2017-9-18
H83
Flight distance : 18156 ft
AkyHun Posted at 2017-9-18 08:57
Have you updated the GO4 app?
2017-9-18
Sportbike_Pilot
Flight distance : 10278435 ft
I'm quite pleased with the active tracking, quick shots, oh good.
2017-9-18
AkyHun
Hungary
H83 Posted at 2017-9-18 09:01
Yes I did. Sorry I made a mistake in my original post, meant to say updated the app not the firmware. I am still on the 900, that could be the issue or the weak GPS signal. I was in option mode.
2017-9-18
hallmark007
Small remote control icon on app when Aircraft is in the air click you will see quick shot click you then have to select subject draw green box around subject like active track select from 3 options DRONIE, HELIX OR TARGET select one you will be given countdown 321 and off the aircraft will go. Be sure to set your boundaries i.e. How far and how high and how big a circle you want to use and what's safe for your environment.
2017-9-18
calmari
Flight distance : 64944 ft
hallmark007 Posted at 2017-9-18 08:30
Yes it works of a fashion, you can even record via the remote but I am guessing that the new firmware will sort it all out. At least I am hoping so.
2017-9-18
hallmark007
calmari Posted at 2017-9-18 09:36
Be careful setting parameters, and be ready to press X on telemetry because I have had problems with this in the past.
2017-9-18
AkyHun
Hungary
hallmark007 Posted at 2017-9-18 09:18
Than you for the prompt reply ;) my AC was not in the air at the time so that was the problem.
2017-9-18
