Mavic Auto Landing?
1190 11 2017-6-8
fans62c763c9
Flight distance : 812064 ft
http://app.airdata.com/main?share=YiZvwS&page_id=GENERAL
Anyone have any idea of the last part of the flight about the "Auto Landing" Mode?
2017-6-8
Jenee 2
Flight distance : 7852129 ft
Well I hope you can read chinese as you have a couple of entries in that language. No idea why.
Let's hope someone from DJI can make a comment.
2017-6-8
fans62c763c9
Jenee 2 Posted at 2017-6-8 21:52
Oh yes I do, actually Chinese is my first language.
Seems all battery and signal is running perfectly but a bad GPS(around 10) I would say.
Anyone have same experience? I am afraid it won't land on a road with out cars and people.
2017-6-8
Jenee 2
fans62c763c9 Posted at 2017-6-8 22:21
Actually your gps was as low as 7 which is not good. I really think you should find a better place to fly.
2017-6-8
fans62c763c9
Jenee 2 Posted at 2017-6-8 22:37
Yes , agrees to you.
But I wonder it gonna work under Atti mode and still questing about what triggering the Auto Landing mode?
2017-6-8
Jenee 2
fans62c763c9 Posted at 2017-6-8 22:51
Are you sure you did not accidentally tap on the icon on the screen for landing?
2017-6-8
fans62c763c9
Jenee 2 Posted at 2017-6-8 23:00
Should be not, because the Auto Landing is unable to cancel... I think this is the difference between normal Landing and Auto Landing, and the attitude is to high for a normal land I guess?
2017-6-9
Ex Machina
Flight distance : 1806362 ft
Were you flying near an NFZ?
2017-6-9
fans62c763c9
Ex Machina Posted at 2017-6-9 06:46
I am not sure... is that possible to check on DjiGO?
I mean the record
2017-6-9
Ex Machina
fans62c763c9 Posted at 2017-6-9 07:28
I mean the record
You should have received warning alerts. You should be able to review your list of warnings in the app's General Settings, but you can also check the location where you were flying here: http://www.dji.com/flysafe/geo-system/map
2017-6-9
Jenee 2
fans62c763c9 Posted at 2017-6-9 06:23
You can cancel an auto landing. Just tap on the Red Cross and then confirm.
2017-6-9
fans9639465a
Flight distance : 187940 ft
Just had a similar problem.
I've had my Mavic Pro for over a year now, and am an experienced pilot. I fly it at least 2-3 times a week just to stay in practice, and consider myself to be a competent pilot with it.
I was out flying my Mavic Pro, completely away from ANY restricted airspace or geofencing. Around my neighborhood as always with no problems.
I was out getting used to the fixed wing mode, and having a great time.
Everything was going smoothly as usual, until I came close to the limit (25%) on the battery power. So, like always I hit the return-to-home and was watching my drone start heading back for a regular landing.
Unfortunately at just the wrong time a headwind started to pick up and getting home was going to be close, but still possible. However the battery level was dropping quickly, and then at 13% battery the drone went into it's automatic landing mode.
I tried to cancel the automatic landing mode so I could fly it another 190 feet to the road where I could land safely.
However when I went to cancel the automatic landing mode, the button was grey and I was unable to cancel it. I tried everything I knew to get out of the mode while I still had about 10-13% battery, but nothing happened!
I've had to do this before (with less than 10% battery), and successfully cancelled the auto landing mode, flew the drone about 300 feet to a safe landing site.
However when I tried to do just that, I COULD NOT CANCEl THE AUTO LANDING!
I'm fighting with the controller, trying to figure out what was happening and the drone just hovered above a bunch of pine trees because it wasn't a good landing place.
If I were able to cancel the auto-landing, fly it manually another 190 feet I would have been able to land easily and safely on a dirt road.
Instead the controls would not respond to anything, and eventually the drone ran out of battery power, the props stopped and it landed in the top of an 80-foot tall pine tree!
It looked like it had a rather soft landing in the tree, I just hope it wasn't damaged.
Since the forest is so dense it's difficult to even find it, I'll have to go back out tomorrow and search for it. I don't even know if I'll be able to see it up in the tree.
So my question is why the hell did DJI make it so you can no longer cancel the auto landing? You used to be able to do so, but now you cannot!
If I had been able to cancel the auto-landing like before my Mavic Pro would not be stuck 80 feet up a pine tree!
DJI should have warned all its users about this critically important change to the firmware, had I known I would have changed how I fly it.
DJI FIX THIS, NOTIFY YOUR CUSTOMERS WHEN YOU MAKE RADICAL CHANGES THAT COULD AFFECT THE SAFETY OF OPERATING A DRONE!
After reviewing my flight log, I noticed that I started the RTH at  about 40%, it flew for only about 1 minute or so and the battery suddenly dropped to 20%!  I'm guessing that this battery is nearing the end of it's life. Also when it stopped to do the auto-landing due to low battery, after about 20 seconds it went from 13% to 10% and then almost immediately went to 1%.
Looks like if I ever get the drone out of the tree I'll be buying a new battery.
Regardless, if I was still able to have cancelled the auto-landing like I had to do a couple times previously I could have flown my drone a short distance to a safe place to land it!
DJI changed something that made flying the drone LESS SAFE!
DJI FIX THIS!
2019-4-21
