4 pro plus software problems
604 2 2017-6-9
fansc9476f58
I have updated software after many tries it gets to 99%then no more no camer feed red blinking light on RC no signal on screen any help will be appreciated
2017-6-9
DJI-Mark
Hi, I understand that you have a firmware update to 99 percent. Can you restart everything and see if the firmware update took? As a suggestion, I always make sure that everything is charged up and you are looked up to a Wi Fi network. If need be, give the aircraft time to cool down before starting. Let us know the end result.
2017-6-9
fans417abfbd
Flight distance : 434593 ft
Are you updating your RC before your AC? You should update the RC first otherwise according to the download instructions it can cause the update to stall.
2017-6-9
