hallmark007
Flight distance : 9812789 ft
I have had this message when I was on 0600 , it just means your App is set up for the country you are flying in. I.e. If you try to set your height higher than your country's regulated height you will be asked the question , are you ok with this and you have a choice to say yes or no, so. Responsibility for setting a higher altitude is yours as it should be, your OA warning has nothing to do with this.
I presume if you move to another country you will receive same warning. |
