No more authorization zone since last firmware 01.04.0602 ?!?
1146 9 2017-6-10
fanse40d873c
Flight distance : 70778 ft
Switzerland
I own a P4P since not very long and my home is inside an authorization zone (Lausanne / Switzerland). I was very happy to be able to fly there with the authorisation system (to accept the 2 safety rules and then, the autentification via my phone with the code returned).
Now, with the new firmware, it does not work anymore. System always said I am into a "No fly zone" and forbid me to takeoff ?!?
Just to rest, I tried to change location, going more far away from airport (about half the radius of the yellow zone), but the result was the same. Impossible to get the permission to fly.
DJI, did-you suppress this system or is it a bug in the new firmware ? What can I do to fly again at my home like before ?
2017-6-10
Duchunter
Go into the setting and turn the geo system off and you should have the same option to accept responsibility as before.
2017-6-10
fanse40d873c
Switzerland
Duchunter Posted at 2017-6-10 11:49
Dutchunter, where in the settings ?!
I inspected all DJI GO 4 application but didn't found where I can disable this.
2017-6-10
Duchunter
fanse40d873c Posted at 2017-6-10 12:29
General setting, bottom of the page.
2017-6-10
Duchunter
Here it is.
Geo
Geo
Geo
Geo
2017-6-10
fanse40d873c
Switzerland
Duchunter Posted at 2017-6-10 12:59
Here it is.
Duchunter, like you can see on the pictures here after, this is a setup I don't have in my Android version of DJI GO 4 software. I suppose you have IOS version.
2017-6-10
fanse40d873c
Switzerland
Eh guys! Am-I alone to suffer from this problem or have some other pilots experienced the same ?
2017-6-10
racer888
Flight distance : 99970 ft
seems that selection is gone after the latest update.
2017-6-11
fanse40d873c
Switzerland
Just discovered that this setting is only available, when all is connected and active. Don't ask me why !!!
So, I was able to test what you suggested, but unfortunately, it does not work.
2017-6-12
fanse40d873c
Switzerland
UPDATE:
I have downgraded my firmware to previous version, but it does not restore the authorization system. Beurk !!!!
Apparently, the new firmware has nothing to do with the fact that authorization system does not work anymore and the map does not display any zones like before.
2017-6-12
